Re: Instrument Track Commit results in huge audio delay
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
So deactivate the plugins one by one and see which ones are causing the problem maybe you have a plugin that is not updated that is reporting incorrect delays I have committed hundreds of tracks and even using plugins with outboard - Track commit has been 100% sample accurate for me |
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
So, metalmixer, thanks for trying to help out! You are in fact completely right that a misbehaving plugin in the session could be responsible for this behavior. However, no (active) plugins were present in this session. I will try to do further troubleshooting later today and, just to be sure, actually remove every single plugin from their slots before I give Commit another go. Fingers crossed! |
Try doing this with all plugins deactivated instead of removing them from the session first and see if that changes anything. Here is how to:
To load a session with plug-ins inactive, use the “Open Session” command (or hit command+O [Mac]/control+O [Windows]). Select the session you would like to open, then hold the shift key while clicking the “Open” button. You could also hold the shift key while double-clicking on the session you want to open, or select the desired session, then hold the shift key while hitting the return key to select “Open.” Quote:
Best Regards Christopher #thestruggleisreal ————————————— South Side Music Group WEBHOME ————————————— |
#16
This afternoon, I had contact with Alicja Goliane from Avid, who is investigating the issue, which I have reported as case 03120087. I'll just post here what I have updated the case with a few minutes ago:
Before I started, I trashed PT preferences and also I started from a completely blank project in PT HD 12.7. There are no plugins on the session, LLM and Delay Compensation are enabled. In I/O setup, both Compensate for input/output delays after record pass are enabled. The buffer size is on 128 samples. I have then tried the following: 1. Sending MIDI -> (external) Nord E5D -> Audio results in around 350 samples latency on the recorded audio. Blue mode makes no difference. 2. Sending Instrument Track MIDI -> (external) Nord E5D -> Audio results in around 350 samples latency on the recorded audio. Blue mode makes no difference. 2. Sending Instrument Track MIDI -> (external) Nord E5D -> Instrument Track Commit in Online mode results in around results in around 4600 samples (!!!) latency on the recorded audio. Blue mode is unavailable in this context. As you see, in ALL of the scenarios above, the ADC does not work. This confirms that neither regular bouncing to disk nor committing works properly in Protools. In my view, this is a very, very serious issue. |
#17
What happens if you turn LLM off?
#18
I can hear you! But this problem has always been present in Protools. Most DAWs have automatic delay compensation on their midi playback, Protools don't. Every time I use an EXTERNAL synth, if I sequence it on Protools, It will always play back out of sync against your recorded audio, even more if you use plug ins in your session. Avid knows about this, and their solution to this problem was the "midi offset" preference which you can set per instrument or globally. This is a PITA because that number will vary depending on which plug ins you have on your session. Sent from my iPhone using Tapatalk Last edited by del cosmos; 01-12-2017 at 01:39 AM. |
#19
#20
This is probably related to the MIDI Thru problem with external where MIDI Thru is being compensated by some value related to audio buffer size. So the larger the audio buffer, the greater the offset. This indicates some basic misunderstanding on the developers part of the way PT should handle external instruments vs VIs. There are a couple of threads around regarding this and IMO it's a bug.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Pro Tools crashes trying to Commit an instrument track Rewired with Reason | mrbenjaminspeed | Pro Tools 12 | 5 | 09-06-2020 01:20 PM |
Automatic Delay Compensation - PT 12.4 - Instrument Track bug | swfeathers | Pro Tools 12 | 8 | 09-04-2018 09:27 AM |
How to set up delay right in instrument track | Natanel Arnson | Pro Tools 11 | 2 | 12-20-2016 06:54 PM |
11.2.1: Instrument Track delay compensation problem | rainsong | Pro Tools 11 | 14 | 08-20-2014 03:43 PM |
strange message when trying to commit to an elastic audio track | gibsy | General Discussion | 2 | 12-19-2013 03:07 AM |
