Using plugins to simulate a sustain pedal.
Does anyone know how to create a sustain effect using the right combination of plugins? For example, a guitar note that rings out for a long time.
Thanks, Marc |
Re: Using plugins to simulate a sustain pedal.
Well, sansamp can do this, amplitube also probably has this capability... They simulate amps. is that what you're looking for? remember, Garbage in, garbage out, so you're best getting the sound right in the first place.
a light reverb and a hard compressor can also bring up the trailing end of a note to make it seem like there is more sustain. A chain may be signal->reverb->compressor->sansamp->limiter. Though someone else will probably have a more authoritative solution, that's just the first way I'd try it. Good luck! -Olaf |
The dreaded sustain pedal | cabdriver | MIDI | 1 | 05-27-2011 06:57 AM |
sustain pedal problems in 6.4LE | tromostheory | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-29-2009 09:24 AM |
Make my sustain pedal a kick pedal | dr beef | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-11-2005 12:20 AM |
Make my sustain pedal a kick pedal | dr beef | MIDI | 0 | 05-08-2005 10:14 PM |
Sustain Pedal | stut5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-04-2003 11:45 AM |
