CS-10 controller on Freq/ Bandwidth/ plug-ins???
Has anyone using a CS-10 control surface gotten the Boost/Cut, Frequency, or Bandwidth knobs to do anything in Pro Tools?
I've got the plug-ins highlighted (blue highlight on the plug-in window, red hightlight on the track name) but nothing happens when I send those control messages. Not even trying it with the simplest 1-Band EQ from the DigiRack plug-ins. Thanks, Leigh |
Re: CS-10 controller on Freq/ Bandwidth/ plug-ins???
They work for me. You have to assign an eq plug in (parametric) to a channel and open the plug in. then arrow around.
click an arrow after opening the plug in. then the knobs control the parameters (of all plug ins) from top to bottom on the plug in and from top to bottom, left to right on the controller. it's kinda neat once you figure it out, it did take me awhile. |
Also, I've made a little utility to display the switch mode (which is cycled through with the "Master Status" switch on the CS-10). It may be helpful in keeping track of what's going on. Download the Pro Tools Mode Display for free at: www.netspace.org/~leigh/max/ Leigh |
cool. ya got one for a JL Cooper fadermaster?
BFh 08h 7Fh ...which is spec'd by Digi as the Mode switch in the MIDI Control Surfaces guide. It then cycles through a list of the 6 modes: Mute (Default Mode) Recall Memory Location Track Selection Track Record arm Target Channel Strip (For Pan, FX and Send levels) Solo So give it a whirl! Leigh |
USB bandwidth problem | JoeyTouch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-02-2010 05:16 PM |
What is the bandwidth of one HD core card? | captainfargle | Pro Tools TDM Systems (Mac) | 3 | 10-01-2009 01:20 PM |
MBOX2 taking too much USB Bandwidth | rolleys.com | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-15-2008 07:56 AM |
EQs - Q's - and Bandwidth | Vic D | General Discussion | 3 | 10-08-2003 05:10 PM |
Why limited bandwidth? | maxserg | Pro Tools TDM Systems (Mac) | 0 | 04-26-2001 08:38 PM |
