direct connect distortion
Having searched the answerbase and forums for help with this, I wonder if anyone else has had this problem:
nastily distorted sound from DC instruments There are no peaking meters either on the instruments I have tried or on the inputs to pro tools Any help much appreciated Beardeddubster |
Re: direct connect distortion
wrong clock? 48k? 44.1k? Optical? Internal? SPDIF? I get this in reason if I change my clock to 48k.
buffer size is at max--still no joy---instruments output fine out of soud manager with pro tool sstill running--surely DC itself can't use up much CPU power?
Any more suggestions gratefully recieved |
No, no.
Its the HW buffer size. The CPU cant keep up. Increase the buffer size one step and your problems will be solved.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Some instruments allow you to change its biffer size in like " Audio setting" in Menu.
Does it also help?? |
bumpety bump
Still stuck with this one--tried all the above Digi tech suppt? |
Which DC instruments are u using?
You don't mention what your computer set up is either - that might help. We're running FM7, Absynth and MSP all through DC without any problems on a G4 733 MHz. Good luck, Mike. [img]images/icons/smile.gif[/img] |
thanks for replying, mike
I am on a 400mhz g4 powerbook, 384mb ram Digi 001 with 1 CB1H magma chassis using ugly vsti with delay lama instrument also B4 (direct connect not RTAS) Got more I haven't tried yet.. 100mb ram allocated to pro tools 90mb to DAE |
What version of DC and Stream Manager are you using?
The behavior you describe can happen you are using a version of DC with a 128 sample buffer: "A side effect of the lower buffer size is a higher load on your host CPU. In extreme cases, you might not be able to reach the same level of performance achieved with the standard version of DirectConnect. If you experience excessive "low CPU" warnings, or even audio dropouts, we recommend going back to the shipping version of DirectConnect." http://www.digidesign.com/download/dc.html Brent |
ok thanks, Brent, for coming to the rescue again
direct connect | nodoze123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-06-2002 03:09 PM |
Direct Connect? | RGrierson | Pro Tools TDM Systems (Mac) | 1 | 02-05-2002 09:58 AM |
dynamo/reaktor distortion direct connect | graphite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-01-2001 09:10 PM |
Direct Connect for NT? | Echo studios | Pro Tools TDM Systems (Win) | 1 | 06-29-2000 03:25 PM |
Direct Connect | asouter | Tips & Tricks | 6 | 10-10-1999 12:17 AM |
