Old 08-25-2021, 06:54 AM
rantanplan rantanplan is offline
Default Re: Media Composer, Poly Channel Files + AMA = Lots of troubles??
Originally Posted by smurfyou View Post
Have you tried an embedded AAF?
Wow, that worked! Finally I can relink the original field recorder files without timecode issues.
Thank you so much for the hint.
I didn't try this because I read in many forums that embedded AAF should not be used or does not work at all with PT 10...
Old 08-25-2021, 06:57 AM
Originally Posted by its2loud View Post
You should be able to export a larger AAF file by checking the “AAF Edit Protocol” box.
https://avid.secure.force.com/pkb/ar...ow_to/en389451
We're also trying this right now. Thank you for the hint!
The export from AMC has worked (6 GB size) and I am waiting for the upload to finish...
Old 08-25-2021, 08:28 PM
smurfyou smurfyou is offline
Well I don't remember the particulars of PT10 but telling Avid to make an embedded AAF is a way to force the AMA media to consolidate. Otherwise it will try to point to it's original location or show an error like you posted.
It could be that in PT10 the original metadata isn't translated from an embedded AAF... I seem to recall an issue with that at some point but that could have been a Premiere issue. Anyway I hope you're able to work with this one.
~Will
Old 08-26-2021, 08:54 AM
The embedded AAF larger than 2 GB also worked.
Yes, the conforming process for embedding media seams to be more sane than the one for copying files to a folder.
Both methods didn't remove the meta data.
But with external files their timestamps don't match the ones of the original files anymore. I think it's bug because it re-encodes them but not to the original length. Hence it's more like consolidating them but without correcting the timecodes.
Cheers,
Till
Old 08-27-2021, 08:04 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
2GB file limit is for OMFs, not AAFs.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
  #16
Old 08-28-2021, 05:02 AM
As @its2loud mentioned you have to check the option “AAF Edit Protocol”. Otherwise Media Composer complains about too large files...
  #17
Old 08-28-2021, 08:11 PM
Vedat's Avatar
Quiet Art Ltd.
That must be an MC limitation. Adobe Premiere is happy to do it.
Vedat
QuietArt.co.nz
Catchin' SYNC app
  #18
Old 08-30-2021, 11:23 AM
Maybe they just kept this as the default setting for compatibility reasons. AFAIK this limit of 2 GB was only an issue on some older file systems and not of the rendering software itself.
HTML code is On
AAF from Media Composer error, "media file's location" Diosan Post - Surround - Video 7 07-10-2018 03:10 PM
Media Composer AAF clips referencing incorrect section of media David McCarthy Post - Surround - Video 13 03-30-2017 12:11 AM
Will pro tools be able to play media composer files? snacky Pro Tools 11 0 04-20-2013 12:12 AM
Media Composer 5.5 (avid) export of AAF file gives NO HANDLES on audio files SplinterMathwood Post - Surround - Video 1 02-28-2012 05:52 PM
AAF Files From PT 9 into Media Composer 5.5/TRUE COMPATIBILITY mysteron Post - Surround - Video 13 07-14-2011 11:44 AM
