PT Freezes when recording midi
When I record any midi data for a period of time, pro tools will lockup, the midi plasma meter will freeze, and playback/record functions stop working. The only resolution is a hard reboot. I've checked all my keyboards (which are running into a midiman midisport 4x4 USB interface) to see if a midi echo or thru is turned on, but they're all off. What else can I do.
Thanks |
Re: PT Freezes when recording midi
You can try some things to narrow down what's going wrong.
- try one keyboard at a time? - try using the Digidesign MIDI interface (you have an 002 Rack, right?) - if you're recording notes played on a keyboard, but actually generating the sounds in the computer (Reason, etc), don't run a MIDI cable to the inputs on your MIDI keyboard. These aren't suggestions for a solution, these are suggestions of things to try to see if you can make the problem change. That's often the path to a solution.
Quad 2.5 G5, 4.5G RAM |
Recording Midi freezes hangs Pro Tools | jallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-26-2007 06:17 AM |
MIDI recording freezes PT 6.0 & 7.0 | sircharles2 | MIDI | 7 | 08-08-2007 04:40 PM |
PT freezes when recording MIDI from MPC 1000 | Yosamite | MIDI | 0 | 03-20-2006 08:01 AM |
Midi Recording Freezes session | 6figgas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-24-2006 06:58 AM |
Recording Midi freezes up PT... WHY... *HELP* | toomuch | MIDI | 1 | 04-18-2005 08:59 AM |
