Old 09-19-2022, 04:16 PM
[email protected] ctstahl@gmx.net is offline
Default Automation EQ3 7-Band automation
Very simple: a certain passage of an accustic baroque instrument needs a very quick EQ adjustment around 3.7 kHz. No problem with the 7-Band EQ, but: I want to fade "enable" in automation in and out. Now with Pro Tools 10 "enable" pops in and out, it doesn't fade gradually.
This is a classical recording, so it needs to be very subtle. I tried using input level or output level for the same thing, but that semms to be working in a different way from way I expect.
I am confused, because this was very easy with Garage band and seems to be impossible with Pro Tools?
Any help very welcome, it is needed!
Old 09-19-2022, 05:35 PM
BScout BScout is offline
Default Re: Automation EQ3 7-Band automation
automate the gain/level of the eq band. From 0 to plus or minus and then back to 0. Don't automate enable. Leave that enabled. Enabled with the gain/level knob at 0 does nothing (which is what you want when it isn't supposed to be working)
Old 09-19-2022, 07:32 PM
nednednerb's Avatar
nednednerb nednednerb is offline
EQ3 7-band is very transparent.
You can have the EQ insert enabled the whole time. No gain, no cut, no effect to signal should be expected.
Then, as BScout mentions, "automate the gain/level of the band".
If for some reason you just didn't want the EQ running 100% of the time, you can combine the band gain automation (where you get the fade) and ALSO earlier and later turn the EQ on and off.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 09-20-2022, 02:47 AM
martthie_08 martthie_08 is offline
if you have Ultimate you might also want to try using clip EQ,
I use it all the time for quick adjustments
Old 09-20-2022, 07:48 AM
smurfyou smurfyou is offline
I was going to suggest that but OP is on PT10 so no go.
~Will
Old 09-20-2022, 09:37 AM
Got it - simple enough. Works fine, and thanks a lot to all!!!
Old 09-20-2022, 10:52 AM
nsureit nsureit is offline
I automate EQ and other plug-ins all the time using touch mode on a playback pass.
Old 09-20-2022, 06:24 PM
Sardi Sardi is offline
Thankfully no longer an Ultimate only feature. Now available in PT Studio.
CEDAR DNS One Band Gain Automation not Working shamrock725 macOS 3 10-11-2017 05:32 AM
difference between MIDI automation and Audio automation on Instrument Track? mariam Getting Started 5 04-28-2016 03:55 PM
Can't turn off capture automation on the automation panel tandem Post - Surround - Video 0 07-16-2014 09:36 PM
Protools Automation to AAF Media Composer Automation TommyT Pro Tools TDM Systems (Mac) 1 08-10-2011 01:40 AM
automation issues (re-writing automation when it shouldn't) revere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 02:41 PM
