Old 11-15-2021, 04:05 AM
PhilipKapadia's Avatar
PhilipKapadia PhilipKapadia is offline
Default Audio Clip Mixer
Hi again,
Thanks once again to everyone who has responded to my previous threads on this forum. That's much appreciated.
I was wondering if Pro Tools had an Audio clip mixer, rather than the standard audio track mixer?
I would like to change the volume of two different clips on the same track, but with a mixer (rather than an individual slider next to the track).
I'm working in Audio Post and I have lots of SFX which I want at different volumes, different pans, but most of the SFX are on the same track as each other.
[email protected]
https://philipkapadia.com/stuff
Media Composer & Nexis Shared Storage ACSR
Old 11-15-2021, 04:16 AM
Sardi Sardi is offline
Clip Gain.
Either show the Clip Gain line or just adjust the small volume slider in the bottom left of the clip.
Old 11-15-2021, 04:33 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Audio Clip Mixer
No, not that I'm aware of.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-15-2021, 06:32 AM
Tweakhead Tweakhead is offline
Sardi's tip.
Pro Tools Ultimate users can also choose to display Clip Effects. Each clip can contain live Gain, Phase, EQ, Gate, and Compression/Limiting adjustments - which use virtually zero DSP power (each section can be "powered off"). You can save instant presets which can by applied be selecting single/multiple clips and pressing one of the 1-5 buttons in the Clip Effects window.
Apparently a session containing these can be read in non-Ultimate, but not changed - so be mindful who you are collaborating with.
screenshot:
https://www.protoolstraining.com/ima...2-1280x317.png
Avid Tutorial: (try to get past the introductory zoom-garbled voiceover . . . it switches once Andrew Hage starts talking)
https://www.youtube.com/watch?v=rrid4Ms1uf0
this guy Ryan Demaree's quite good too, and quickly explains it:
https://www.youtube.com/watch?v=dUk36ruVUh8
tip: download a higher-resolution mp4 video by going to one of the many YouTube>MP4 converter sites which will allow you to save a 1080p version of the video - such as this one
Selecting a clip in Edit window fails to select clip in Clip List oldskool Pro Tools 2020 8 09-28-2021 01:43 AM
Nudging a clip past another clip removes the stationary clip evil.beasts Pro Tools TDM Systems (Mac) 0 11-01-2017 11:08 AM
Trim audio clip to next audio region. Wawili_Sound Pro Tools 12 7 06-28-2017 11:49 AM
Importing audio extends the audio clip (I checked sample rate) Lonus Pro Tools 11 1 01-04-2017 05:15 PM
Eucon control over M-Audio Profire DSP Mixer/Focusrite DSP Mixer? finkbmx Artist Series 1 12-26-2010 12:11 AM
