Old 12-27-2012, 02:48 PM
artmcosta artmcosta is offline
Default Serial number not accepted.
I just bought a crossgrade from Avid store PT Le to PT 10, and the serial number of my Mbox Pro 3 is not accepted when trying to download. Since the response from store is none, I would like to now if anyone can help me.
Thanks
Artur
Old 12-27-2012, 03:23 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Serial number not accepted.
Originally Posted by artmcosta View Post
Thanks
Artur
Are you definitely using the serial number and not the product code!
Did you buy the unit new? (incase the serial has been used already)
did you get any massage when you tried to use it? or did it just not get accepted?
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-27-2012, 10:08 PM
Royce Royce is offline
Having the same problem with my digi 003. Have you gotten any assistance? Thanks
Old 12-29-2012, 11:59 AM
I had assistance, not very common though because I had to call to Spain (I live in Portugal). It's odd that the customer doesn't have the possibility to e-mail some one. But at least now I understand the problem. I bought a mbox pro 3 without the PT software and so this mbox is not eligible to cross-grade. I also get the information that I could cross-grade through a Mbox 1st generation which is associated to a PT LE 7, but in the online store says that mbox 1 is not supported. I tried the mbox 1 serial and is not accepted. I'm waiting for further information.
Old 12-29-2012, 12:04 PM
Default
The Mbox 1st generation does not qualify, so that will not work. You may need to try to return this upgrade software and purchase a full license.
Darryl
Old 12-29-2012, 12:12 PM
Default
How can you be having the same problem? Your digi 003 came with a version of Pro Tools LE. What exact problem/symptoms are you having?
Are you entering all the characters correctly? Be careful about 8 and B and 0 and O etc. Are you entering the correct string being asked for? hardware serial number vs software license number? I cannot even remember the cross grade steps I followed.
Did you purchase the 003 new? If not it may have already been used for a crossgrade.
At the bottom of the Avid Audio Product Registration web page there is a link on how to get registration help, you can try there.
Darryl
Old 01-03-2013, 05:21 AM
I contacted Avid support and they told me that I can cross grade, after all. I already have a ilok license.
Thanks for all the replies,
Artur
Crossgrade LE8 to PT10 serial number not accepted neilskene macOS 2 12-30-2011 05:48 AM
Pro Tools 10 download: serial number not accepted" shelbyjames macOS 0 11-18-2011 06:54 PM
SOLVED! EXRP installation problem: Serial no. not accepted therealmf Eleven Rack 0 05-31-2011 05:59 AM
HD Core Card serial number not accepted Hughbacca Pro Tools 9 9 04-07-2011 01:30 AM
Serial Number ?? johnnymonaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-30-2002 03:38 PM
