Can\'t Install Hybrid update or Velvet
I've got Hybrid and went to install the downloadable update and get an error in install message. I get all the way to installing it and it quits saying "try installing again". This also happens with Velvet.
I have a G4 Quicksilver ( Giga Design 1.8 GHz processor upgrade) w/ 1.5 GB of RAM running OS 10.4.9 |
Re: Can\'t Install Hybrid update or Velvet
Start with Hybrid and see if this helps...
First, you must have the Hybrid v1.x plug-in installed in order to run the 1.5 updater. If Hybrid is in your plug-ins folder, and it won't update to v1.5, try this... Using the information here as a starting point: http://www.digidesign.com/index.cfm?...4&itemid=23022 Quote:
Hybrid Setup.pkg Hybrid_1.5.0.x5326_Update_OSX.pkg Delete all of those files, plus the Hybrid files in your Plug-ins folder. Then run the Hybrid v1.0.1 installer: http://www.digidesign.com/index.cfm?itemid=4863 Then run the Hybrid v1.5 update.
Administrator Avid Pro Audio Community |
Thanks for your reply. Tried it, but still got the error when trying to run the update. Also Velvet is still producing the same error. This is very frustrating to have purchased instruments for projects and can't use them.
Have you deleted preferences with the Tech Support Utility?
Are you logged in as an administrator on the Mac? When you tried the steps above, did the Hybrid 1.0.1 install? If not, this sounds like you might need to reinstall Pro Tools.
Tech Support Utility? Do you mean Disk Utility?
And yes Hybrid 1.0 did install, but not the upgrade nor Velvet. |
One of the Quick Links in the Support section. Also, do a Get Info on your plug-ins folder (the actual folder, not the alias) and check to see that you have read and write privileges.
Strike, Velvet and Hybrid don't work with new pt 10 update | elvolutionstudios | macOS | 23 | 09-23-2013 12:45 PM |
Will Pro Tools 10 still run Velvet,Strike, Hybrid | Dan Tomlinson | macOS | 2 | 06-28-2012 08:00 AM |
Any upgrades planned for Hybrid and Velvet? | GiveMeApps | Virtual Instruments | 2 | 08-31-2011 10:02 AM |
Hybrid and Velvet demo assets | taiazeez | Pro Tools TDM Systems (Mac) | 1 | 12-11-2006 09:16 AM |
Hybrid and Velvet demo assets | taiazeez | Pro Tools TDM Systems (Mac) | 0 | 12-09-2006 09:55 AM |
