  #81
Old 07-05-2021, 07:22 PM
off the wall's Avatar
off the wall off the wall is offline
Default Re: Upgrading a Mac Pro 5.1 12core 2.4Ghz
Originally Posted by kings79 View Post
What's the benefit of OC with Mojave?
You get the boot screen with a Mac flashed Metal GPU like I have.
Re-Recording Mixer
If you already have a Mac flashed metal GPU, just GPU video acceleration. I have a generic RX580, so having a boot screen and volume picker was a huge plus.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
  #82
Old 07-05-2021, 07:26 PM
kings79's Avatar
kings79 kings79 is offline
For sure.
Besides that does OC add anything else to Mojave?
  #83
Old 07-05-2021, 07:34 PM
basslik's Avatar
basslik basslik is offline
For sure.
Off the Wall provided two great links to read.
Most part it also show your PCI drives as internal.
here's the technical list of Martin Lo's configlist.
  1. Boot screen (via GOP for unflashed card, including some Nvidia card)
  2. Firmware protection (to run Windows in EFI mode without risking the cMP bootROM)
  3. HWAccel (H264 / HEVC hardware decode + encode in Mojave and newer macOS up to Big Sur 11.2.3)
  4. ability to watch DRM streaming content (Mojave and newer macOS up to Big Sur 11.2.3)
  5. Boot picker (only support EFI systems, tested with Apple wired keyboard, Magic Mouse, and Magic Keyboard, 10s timeout. If you can't see this. Just don't touch the keyboard, and your cMP should continue to boot to desktop)
  6. NVMe and SATA drives on PCIe card show up as internal
  7. Support for Apple USB SuperDrive
  8. TRIM (regardless trimforce status)
  9. Ability to run non-GUI 32bit software in Catalina
  10. Ability to reset NVRAM in boot picker (disabled at this moment to align with the native Apple boot manager)
  11. Ability to run any natively supported ancient OSX with modern graphic card e.g. Radeon VII in 10.6.8 (only can display, no acceleration) [Update 5th May 2020: Sierra and High Sierra may not fully supported yet. Thanks for pierrox's report]
  12. Ability to boot Catalina / Big Sur Recovery Partition
  13. Sleep should work (tested on my cMP, but I can't guarantee it also work with your hardware)
  14. Possible to run 8x32GB RAM in macOS (user need to mod the config.plist manually. Replace the false below CustomMemory to true)
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
  #84
Old 07-05-2021, 08:09 PM
kings79's Avatar
That's pretty good.
Martin is a good guy. I've known him for a couple of years
Re-Recording Mixer
Re-Recording Mixer/Sound Designer
Sydney Australia
OS Monterey
ProTools Ultimate 2022.4
Presonus Quantum 4848
Mac Studio M1 10 Core, 64gig RAM
Sonnet Echo dual NVMe TB Dock
Blackmagic Decklink 3G
  #85
Old 07-05-2021, 09:28 PM
basslik's Avatar
That's pretty good.
Re-Recording Mixer
Absolutely, him and Alex been a tremendous help.
Off the Wall. I see you are having trouble with the EFI on the nVME ?
Get it resolved ?. I went through that as well. I just made sure I did the 5 chimes, removed all peripherals on the initial install first boot, and I overlooked by accident disabling SIP.
  #86
Old 07-11-2021, 03:16 PM
basslik's Avatar
Off the Wall, you get the NVMe squared away with OC ?
I plan on setting up the OC on a USB. I read on that and it's a great way to keep it from messing up the EFI volume on the OS drives.
  #87
Old 07-11-2021, 04:03 PM
No, I just run it off one of my SATA drives. Works great.
  #88
Old 07-12-2021, 05:58 PM
basslik's Avatar
Very cool. I was doing the same but I'm switching to USB. From what I read it really helpful if something goes wrong just ZAP the Nvram and pull the USB then you back to normal.
You still on Catalina, or did you jump to 11.2.3 ?
Thanks and have a fantastic week.
  #89
Old 07-12-2021, 06:02 PM
No going to stay on Catalina for now unless a future 'current' version of 11.x works reliably on the 5,1.
  #90
Old 07-12-2021, 08:48 PM
kings79's Avatar
Hey Off The wall. Did you do the Thunderbolt mod?
I don't have any PCI slots left!
Sydney Australia
OS Monterey
Mac Pro 12Core vs Mac Mini 4Core.. Mac Mini wins Venshield General Discussion 12 12-06-2017 07:32 PM
Not enough Memory - Mac Pro, 2x2.4Ghz, sonor77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-16-2010 12:25 PM
P4 3.4Ghz compatibility problems! pete66 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 39 01-26-2005 10:06 PM
VIA KT266 AMD 1.4ghz oslpchris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 10-26-2001 07:10 AM
Dell P4 1.4ghz Badooker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-28-2001 01:49 AM
