Old 01-30-2017, 03:40 AM
climber climber is offline
Default Pauses while playing 1st time only
I have and use both Keyscape and Trillium with PT12.6 and 7. Very often when I load a session and then start to play it, it will begin playing properly. Then after a few seconds all the MIDI tracks will drop out,but the audio tracks will continue playing. After around 1 minute or so, the MIDI will come back on, but in the wrong spot. Pressing stop and play will return things to normal.
My guess is that it's got something to do with the VI's loading. Does anyone else see this? It still happens if I wait a while before I press play, so I doing think I can force the load. These aren't huge sessions mind you. 30-40 tracks usually and 3-5 minutes long. I have a fast machine with lots of RAM and fast TB hard drives as well, so that shouldn't be an issue either...
Thnx
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 01-30-2017, 05:08 AM
Default Re: Pauses while playing 1st time only
How many instances of Trillian and Keyscape are you using? Spectrasonics stuff, at least for me, tends to be heavy on cpu & disk usage. Great sounds but resource hogs. I've noticed that patch changes can take a while in Omnisphere which is the same engine as the two you have.
I also see by your sig file you're running ElCrapitan and that OSX version has never been a good performer for any kind of audio work. Any chance you can go up or down an OSX level?
Jack
QAPLA!
Old 01-30-2017, 06:17 AM
ThnX for responding...
10.12 is actually Sierra.
Only 1 instance of each.
I don't do any patch changes.
Really wondering if other Keyscape and Trillium users experience this.
Al Hospers
Old 01-30-2017, 08:17 AM
Open Keyscape and see how long it takes to fully load your sounds. I would simply wait for it to finish(and yes, it is slooooooow)
Old 01-30-2017, 08:22 AM
Then why does your sig file show this: OS X 11.12.1 ?
Jack
QAPLA!
Old 01-30-2017, 08:06 PM
Good question...
Al Hospers
Playing 2 tracks same time yousonics Pro Tools 9 4 08-21-2013 02:55 AM
Playing 2 instrument tracks at the same time Ford Virtual Instruments 2 09-15-2006 02:59 PM
Playing out of time tboyee Tips & Tricks 2 12-02-2005 03:40 PM
long pauses before playing in Win XP! nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 05-27-2003 10:52 AM
Recording at ant time while playing billythekid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-19-2001 11:13 AM
