Old 01-17-2015, 12:10 PM
pmcaster pmcaster is offline
Default Audio recording quality issue
Hello, I'm using my eleven rack as main interface with my MacBook Pro, when arming a track in Pro Tools, I love the sound that I hear through my monitors, but whenever I record, the sound quality of the recorded truck is lower, less clear, less defined, darker.....I have the same issue when using Logic Pro, so, what might be the reason, any special set up in Mac or Eleven Rack?
I would really really appreciate any help on this issue.Thanks in advance!!!
Old 01-17-2015, 03:53 PM
AvidEditor AvidEditor is offline
Default Re: Audio recording quality issue
I assume your monitors are receiving the output from the 11R XLR Main Outs?
Old 01-18-2015, 03:53 AM
Originally Posted by shiftstudios View Post
Are you recording through the Z-Input on the front of the Eleven Rack?
Hello, yes, I'm recording through thr Z-Input, which is normally set up as "Auto"
Old 01-18-2015, 03:56 AM
Yes of course, monitors are connected to the 11R XLR Main Outs, but the issue is the same if I connect the Digital Out to my Motu UltraLite MK3 Digital In through spdif, never get the same audio quality than what is monitored...
Old 01-18-2015, 04:58 AM
Have you checked your session settings to make sure they're in line with the 11R and you're not getting poor quality because of a sync issue?
Hmmm...good question,, how can I check it?what set up/parameters might be involved? Thanks!!!!
Old 01-18-2015, 11:43 AM
Everything seems to be online except the bit depth, which is set by default at 32 bits in 11R and cannot be modified, does it means that all my sessions should be at 32 bits? does it affect to the sound quality?
Old 01-19-2015, 05:16 AM
Ichil Ichil is offline
I've been into a similar situation when I tried to record a stereo rig into a mono track: everything sound dull, too dark and too gainy.
Setting the rig to mono solved the issue (I could record it in a stereo track, but for me it was useless as the rig was a mono one, just set to stereo by default).
Audio and midi recording issue djcreation24 Windows 11 02-03-2014 04:33 PM
Recording System Audio Issue CraveMac macOS 2 09-26-2013 01:14 PM
Mbox 1 vs M-Audio MobilePre - recording quality? Georgerob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-05-2012 04:40 AM
Timing issue when recording audio from MIDI tracks Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-16-2006 07:42 AM
Do audio snake lengths noticeably affect recording quality?? east3rdst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-22-2001 11:29 AM
