Strange 5.1 Master Fader Behavior When Bnc to Disk
This is a strange one:
When attempting a bounce to disk, or for that matter a bounce within the session itself, the 5.1 outputs go into this strange mode where all the outputs are jumbled, kinda of like hearing just reverb returns. For example, if the 5.1 outputs are configured 1 = Lf 2 = C 3 = Rf 4 = Ls 5 = Rs 6 = LFE when trying to bounce to disk or to a 5.1 audio channel, the output is 1 = nothing 2 = nothing 3 = garbage 4 = reverb return 5 = reverb return 6 = nothing The problem ONLY occurs when there is a quick fade-in on the master fader immediately AFTER the bounce start point. Removing all level automation from the master fader eliminates the problem. I can't tell you the things I started to troubleshoot before discovering this issue purely by accident. This problem doesn't occur with a regular stereo session. Just wondering if anyone has come across this or is able to duplicate this behavior. Thanks. |
Re: Strange 5.1 Master Fader Behavior When Bnc to
What is your system configuration?
Hi Jonathan,
Sorry it took so long to reply. I've been doing a lot of bouncing to disk....w/o master fader automation.... Except for some minor static electricity problems involving the 192 interface, the system is running fine other than the situation described in the last post. PT 7.1cs4 192 I/O firmware v 3.0 Mac OS 10.4.3 PowerMac G4 1.25 GHz Dual Processor Lacie FW drives using 400 Mb/s ports, formatted as per Digi's recommendations with journaling enabled. Plugs: Waves 360 Surround bundle Waves IR-1 Convolution Reverb Waves Renaissance EQ/Compressor/Reverb Waves S1 Imager Sony Oxford EQ w/GML option Sony Oxford Reverb Sony Oxford Transient Modulator Eventide Legacy bundle Digidesign Smack! Digidesign Pultec bundle Digidesign EQ 3/Dynamics 3 Digidesign Bruno/Reso Focusrite d2 EQ/Compressor Line 6 Amp Farm IK Multimedia Amplitube Elemental Audio InspectorXL Those free Bomb Factory plugs Time/date set correctly, power-saving features off, recommended fonts, etc. set as per Digi's instructions. Digi databases on all drives and PT preferences trashed w/ restart. Thanks, Kurt |
Forgot to mention:
HD3 not Accel |
strange... master fader | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-02-2009 12:15 AM |
Strange Master Fader Issue | michael c | Pro Tools TDM Systems (Mac) | 3 | 03-04-2009 02:44 PM |
Fader Meter Behavior in PT8 and Fader Weights | DrFord | Pro Tools TDM Systems (Mac) | 4 | 01-08-2009 02:23 PM |
Bounce to Disk/Master Fader | stut5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-24-2003 03:49 PM |
Strange 002 behavior | Ricco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-25-2003 06:45 AM |
