Old 04-05-2022, 09:17 PM
Reml@P Reml@P is offline
Default "Reverify" Academic Eligibility Fails
Not sure if this is the correct sub-forum... Mods, feel free to move.
The issue is that attempts to "reverify" academic status fails. I've tried this with multiple web-browsers (Safari and Firefox) but upon pressing "submit," the page shows "this field is required" for date of birth, even though it's already been entered. Re-inputting the date of birth causes the same issue again.
Cheers
Old 04-06-2022, 09:39 PM
Bob L's Avatar
Bob L Bob L is offline
Default Re: "Reverify" Academic Eligibility Fails
A shot in the dark...
Is the form asking for a date in the format MM/DD/YYYY?
You're not inputing DD/MM/YYYY are you? IIRC this is the assumed format in Europe; I don't know what the Oz convention is....
Bob
Without a song
The day would never end
Old 04-06-2022, 11:35 PM
jeffro's Avatar
jeffro jeffro is offline
If you are unable to get this sorted out, please Create A Case under Account Support at avid.com/learn-and-support/contact-audio-and-music-support to provide your account info & System ID. Thanks!
linkedin
Old 04-07-2022, 12:09 AM
Thanks for the reply Bob. No, you just select the year, month and day from a drop down menu and it then populates for you. But as mentioned, it's not working
Old 04-07-2022, 12:16 AM
Just submitted now. Thanks for the link :)
Old 04-07-2022, 08:13 PM
For those interested (had a couple of PM's) I've had a reply from support -- it's a "known issue" that they're currently working to fix.
Old 04-07-2022, 09:32 PM
jeffro's Avatar
Thanks for following up with more info here. I checked and see that your license is current so this shouldn't be impacting your use, and CS should be able to get this resolved soon. Thanks for your patience.
linkedin
Do eligibility requirements include "houses of worship" for educational discount? lampmusic Licensing & Accounts 2 05-06-2017 11:43 AM
audio import fails "863892" bigsnit-media Pro Tools 12 3 06-28-2015 08:28 PM
PT "Academic Version" question...co-artist is in grad school-I'm not JLiRD808 General Discussion 1 09-06-2012 01:30 PM
PT10 - Free Upgrade for "Academic" licenses d.pacchi Pro Tools 10 0 10-22-2011 02:23 AM
le 7 fails to launch at "dae loaded"? dufnas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-08-2009 02:35 AM
