Contemplating A MacBook For PT LE
I'm looking at, new or used, I have a mbox2 micro:
MacBook Pro 13-inch: 2.26GHz Intel Core 2 Duo 4gb Ram 150GB HD (would use external for my audio files) Is this set up good for running PT or are there any issues? And for the price differential (used is not that bad but still) is the 2.53GHz version of the 13inch really worth it? Also, if I already used my PT Authorization code when installing PT LE 8 for Windows (DLed from digidesign) will I be able to use that same one on Mac? - Thanks |
Re: Contemplating A MacBook For PT LE
This should work great - I get excellent performance out of a MBP 2.2 C2D.
Make sure the external drive you get has a compatible FW400 chipset. Typically any Oxford chipset is fine. You can use the same code on the Mac as you used for your PC... |
Oh, and typically the premium you pay for the faster model isn't necessarily worth it. I doubt you would see much of a difference, performance-wise, between this model and the faster one.
I've also had a good experience running PT on my MBP. Runs nice & fast, with few glitches (and most, if not all, of those are my fault -- neglecting to adjust hardware buffer between recording and playback, that kind of thing). The only possible drawback I'd see for you is screen size -- seems pretty small to me. Mine's 17 inches, & I wouldn't mind a larger one. But if you've got sharp eyesight (and/or a tight workspace), I'd say go for it!
MacBook Pro, OS 10.6.2, Intel Core 2 Duo, 2.6 GHz, 4 GB Memory, 003 Factory, PT LE 8.0.3, G-Tech G DRIVE Q 1TB HD ------------------------------------------- 'Wave of the future, Dude. One hundred percent electronic.' -- J. Treehorn |
The only major issue with the non-Pro MacBook is the terrible LCD. The size is manageable, but the actual LCD is awful. The viewable angle is pretty narrow, and you'll find yourself shifting the screen quite a bit. Fine for tracking, but it can be fatiguing if you are mixing for long periods.
Performance-wise, it runs great. Honestly, the difference between my MacBook Pro and my MacBook is insignificant. The best upgrades are cheap; 4gB RAM and 7,200rpm internal drive.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Keep in mind you get get a 22" monitor for under $200 and connect it to the DVI port on the MBP...
Indeed. Depending on the version of the MacBook, you only need an adapter which can be had on the cheap from monoprice.com .
The only ones to avoid are the ones with no Firewire (first unibody Macbooks). Protools requires an external firewire drive for the audio.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Experiences running Eleven Rack with a USB3 MacBook Pro or MacBook Pro Retina? | Darryl Ramm | Eleven Rack | 3 | 09-18-2012 11:22 PM |
Contemplating Video Satellite | soundworx | Post - Surround - Video | 6 | 02-03-2012 08:05 AM |
Contemplating SSD for Session drive | BrendanClace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-09-2010 02:19 PM |
Contemplating switching to Pro Tools... | wayoutwest | Pro Tools M-Powered (Mac) | 3 | 05-28-2007 12:06 PM |
macbook/macbook pro buffer problems, solution | therecordinghouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-21-2006 04:07 PM |
