No Plugin Presets Recognized
I Just installed the new Novation V2 Automap, and unfortunately it completely renames all your old plugins and adds its new automap ones in their place. This means any old sessions cant find any of their plugins. Once I figured this out I used the Automap manager to reverse what I had done, everything was OK the Sessions loaded fine, but now none of my plugins can find their presets. The presets folder in /Library has not been altered, and even if I goto the plugin Settings preferences and set the Root Settings folder to the appropriate folder - still nothing. The only way I can get a preset to load is to import it which is a real pain if you are used to flicking through to find your sound Any help would be appreciated Cheers |
Re: No Plugin Presets Recognized
You should try trashing preferences, which likely will fix the problem.
I've had the same problem since upgrading to 7.4.
Trashing prefs didn't help. Any idea? This is so annoying... Izhar |
Hypercontrol: Convert plugin build-in presets to pro tools plugin presets | headsup | macOS | 4 | 12-17-2011 01:28 PM |
Getting EZ Drummer Plugin Recognized in PT8 | IndyHoosier | Virtual Instruments | 2 | 02-14-2011 07:25 PM |
BFD - Works but Plugin Not Recognized | EarBud | Virtual Instruments | 3 | 07-02-2009 08:29 AM |
.dpm not being recognized as a plugin! | audioonlyandy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-26-2006 08:02 AM |
Plug-In Presets not recognized | Dog BBQ | Pro Tools TDM Systems (Mac) | 3 | 12-29-2001 12:48 AM |
