Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 06-22-2016, 04:07 PM
JuanPC JuanPC is offline
Default HPET timers vs. Lynx AES16 -&- PT 12.3.1
Tested all settings,
HPET disabled in Bios + HPET disabled in Windows7
HPET enabled in Bios + HPET enabled in Windows7
HPET enabled in Bios + HPET disabled in Windows7
HPET disabled in Bios + HPET enabled in Windows7
The only thing I didn't tested was reinstalling the drivers...ver. 19g
Without reinstalling drivers, Lynx AES16 goes crazy...
Some Random Inputs get DC hum at -12dB,
Lot's of dropouts.
bcdedit /deletevalue useplatformclock
All good again.
If want to try HPET with your pc/interface:
bcdedit /set useplatformclock true
bcdedit /set useplatformclock false
With & without HPET Enabled in Bios.
I recommend at least 2 reboots to let Windows adapt to the new settings.
This only works with boards that have HPET option in the BIOS.
Search WinTimerTester_1.1 if want to verify HPET 14MHz clock is Active.
And DPC Latency Tester / Checker.
Got curious about HPET timers & Audio reading this:
http://www.neowin.net/forum/topic/10...mance-and-fps/
High Precision Timer
Select Enabled to activate the High Precision Event Timer (HPET) that produces periodic interrupts at a much higher frequency than a Real-time Clock (RTC) does in synchronizing multimedia streams, providing smooth playback and reducing the de- pendency on other timestamp calculation devices, such as an x86 RDTSC Instruc- tion embedded in the CPU. The High Performance Event Timer is used to replace the 8254 Programmable Interval Timer.
The options are Enabled and Disabled.
-Supermicro.
--->If you don't like what i wrote:
Click: JuanPC
Click: View Public Profile
Click: User lists^
Click: Add to ignore list.
Solved.
Old 06-26-2016, 10:22 AM
Default Re: HPET timers vs. Lynx AES16 -&- PT 12.3.1
Other thing I could have tested was disabling HyperThreading.
Maybe later...
Click: JuanPC
Click: User lists^
Solved.
Lynx LT-HD lorudess Buy & Sell 12 06-14-2016 07:08 AM
Avid Pro Tools HD3 10/11, 192 i/o, Lynx AES16, Mac Pro, Magma and more! dc_4 Buy & Sell 0 08-25-2015 09:53 AM
FT: Lynx LT-HD for LT-USB acmost Buy & Sell 2 07-16-2012 03:49 AM
Sync Buffer Problem betwen AES16 and PT10 Tooly Windows 3 07-11-2012 07:11 PM
Question for midi guru old timers Donny MIDI 1 02-21-2004 06:52 PM
