Pro Tools failing to load plug-in already in plug-ins folder
Hi there,
After updating my MacOS to Catalina I've encountered a problem when loading one of my sessions. As the only plug-in, Pro Tools won't recognise the TDR Nova plug-in already inserted on one of my tracks. It says that it doesn't exist in the plug-in folder. But it does. And I am able to load it as a new insert, but I can't activate the one already inserted. Any one know how to fix this? I have reinstalled the plug-in, updated Pro Tools, deleted the plug-in from the folder and reinstalled it. Nothing have worked. |
Re: Pro Tools failing to load plug-in already in plug-ins folder
I wouldn't care if it wasn't because the mix is just as well done and the client is happy. But I can't find a workaround. |
Exact version of Pro Tools?
What exactly and when are you getting a message telling you the plugin does not exist in the plugin folder? Did you start troubleshooting by trashing prefs? Does the Pro Tools log show anything interesting? |
And rereading the description: does this happen in other sessions? It may be a corrupted session. Can you delete the existing insert and then insert another?
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
Maybe because he wants the plugin with the settings saved in the session
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
So if trashing the Pro Tools preferences (as Darryl mentioned) does not do it for him Then I see only two other factors #1 If he thinks that plugin is critical to the session then IMO resetting a new instance would be preferable to not having it... Because :: #2 Given he can instantiate a new instance that works ,,, then it is likely something about that specific first instance ,, that is corrupted in that session, and it wont matter if he "wants it with the saved settings " because it probably ain't gonna happen And It's not that complex of a plugin to reset .
But a couple of weeks ago I tried load a session saved in pro tools 10 many years ago. There was an instance of BFD 3 in rtas format that now in aax doesn't load. It tells me that the plugin is not present in the folder. Yes I loaded the aax vs in fefault setting. Well it's very hard to recreate the settings that were saved in the original session. Individual drum instrums, tunings, decays, mics balance etc. Just to say that sometimes reloading the original settings is necessary
Pro Tools 12 Plug Ins Folder Mac OS | shawshank67 | Pro Tools 12 | 11 | 12-06-2017 11:52 AM |
Plug-ins (Boom/Xpand/Structure) failing to load on startup | Lozlizor | Windows | 1 | 05-07-2016 06:26 PM |
"Pro Tools could not load the following plug-ins" on Native Instruments plug-ins | Joachimoj | Windows | 6 | 08-14-2015 04:42 AM |
Pro Tools 9 HD, Plug In in Folder but not showing up | TRNCFRMCN | macOS | 5 | 09-11-2013 12:46 AM |
plug-in folder and cpu load ?'s | steve_o | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-07-2000 07:43 PM |
