Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 11-24-2021, 01:37 AM
ursoctba ursoctba is offline
Default BURL ADC with ADAT connection into MTRX Studio
Hey guys, I'm new to the AVID and PT products, so every day is a discovery for me.
I have already set up my MTRX studio with DVS and Dante Controller. I'm just having difficulty now connecting my BURL ADC via ADAT into the MTRX. I am moving and seeing all the possibilities inside the DADman, but nothing has worked so far.
I already routed my analogue Outputs into my hardware chain ending on the Burl, but I cannot have that digital audio through the Burl to the MTRX.
Any thoughts?
PS: My Burl doesn't have the DANTE option, unfortunately.
Thx
Old 11-24-2021, 03:04 AM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
Default Re: BURL ADC with ADAT connection into MTRX Studio
Any thoughts?
Thx
It would help with some screenshots from DADman.
In any case, have you checked whether you have a green indication on the ADAT input in DADman, as shown in this example?
Do you have any meter indications on the ADAT input in the routing window?
Is the indicated samplerate in the routing window correct?
And finally, have you sync'ed the Burl ADC with the MTRX Studio?
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
Old 11-24-2021, 07:40 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Any thoughts?
Thx
Which Burl product are you using? And, does it definitely have ADAT out and not just Optical S/PDIF out?
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 11-25-2021, 12:56 AM
No, the part from ADAT is with the red triangle.
No, no indicator from ADAT input routing.
Yes, the sample rate is correct for all devices (MTRX and DANTE)
Sync - It's synced by Word Clock
Here is the screen from my actual panel:
https://www.dropbox.com/s/69qvur9c1c...53.26.png?dl=0
Old 11-25-2021, 01:00 AM
Hey Kyle.
I'm using the BURL ADC B2 Bomber. I bought last year.
Yes it have the TOS connection. Picture attached.
I'm getting from the Burl to ADAT 1 IN on MTRX Studio
Here is a print of the back of the equipments:
https://www.dropbox.com/s/03bpw4pa2f...5.17.jpeg?dl=0
Thx
Old 11-25-2021, 02:45 AM
ntp-jl's Avatar
Hey Kyle.
Thx
The optical connection on the B2 is SPDIF which is a 2-channel format.
The optical connection on the MTRX Studio is ADAT which is an 8-channel format.
SPDIF is not compatible with ADAT, so you will not get this connection to work.
An alternative is to use the AES output on the B2 and convert this to ADAT via some external converter.
Jan Lykke
Old 11-25-2021, 02:59 AM
uptheoctave uptheoctave is online now
The Bomber does have a Dante option card, that would probably be the simplest approach to take.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 11-25-2021, 03:01 AM
Ahhh now makes sense. Sorry for the newbie topic, guys.
Another solution is to get the DANTE board for the Burl, right?
Old 11-25-2021, 03:15 AM
Yeap I saw that but here in the UK you don't find those boards at the moments and I need to get the work done as I sold my Apollo x16, which was my previously interface.
Something like this will work? AES to DANTE
https://reverb.com/uk/item/34752680-...io-adaptor-2x2
Old 11-25-2021, 03:53 AM
ntp-jl's Avatar
That could work. However, be aware that the AVIO adapter, and many similar AES to Dante adapters, use samplerate conversion between AES and Dante.
Or as uptheoctave suggests, go for the B2 Dante option if you can get one.
Jan Lykke
Connection Issues with MTRX Studio Ooptron Pro Tools | MTRX & MTRX Studio 10 09-26-2023 02:34 PM
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
MTRX Studio DADman-Network Connection Error pablovius Pro Tools | MTRX & MTRX Studio 39 07-03-2021 10:50 PM
Digi 002, Burl B2 bomber Adat? Please help primomusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-28-2018 03:48 PM
