Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 06-21-2021, 08:07 AM
sleeto sleeto is offline
Default One newly created track has gray wave and no sound
Fairly new to PTF and learning as I go...
I'm working on a project that has 12 stereo tracks. I recorded a vocal track using my microphone on input 1 (left side), then did the following:
1. split track into mono (creating 2 additional tracks, 1 with vocal and 1 with nothing)
2. copied left side (vocal) and pasted to blank right side (creating two identical mono tracks)
3. dragged both mono tracks back into original stereo track (overwriting the left-side-only version)
Now, the new stereo track is muted/silent/unlinked (not sure what to call it). The wave is there but it's gray instead of black and the track is completely silent when played. All other tracks are functioning properly. I have done this process to create stereo vocals several times before with no problems.
What's happening? Also, if the wave is there but just not visible, is the file not linked somewhere? How can I find it and re-link?
Old 06-21-2021, 11:20 AM
Sardi Sardi is offline
Duplicating the same track, panning it left and right or placing it on a stereo track track does NOT make it a stereo file. There’s nothing remotely stereo about the audio. All you have is a dual mono file. The audio is still straight down the middle of the stereo spectrum.
Why are you doing this? What are you hoping to achieve?
Also, in PT, when a track is grey, it means the clip is muted. You can have muted clips on a track. When the play head crosses that file, no audio is heard.
Old 06-21-2021, 01:11 PM
Default Re: One newly created track has gray wave and no sound
Indeed, record a mono source to a mono track(examples of mono sources: vocal, bass, guitar combo amp, saxophone....).
Sardi's mention of the clip being muted is likely and Ctrl+M (on Windows) will toggle that(not sure what the Mac version is, probably Cmd+M with the clip highlighted/selected).
If that's not it, check that the track has a valid output.
Old 06-21-2021, 03:33 PM
Thanks for the reply. While I understand your point, with a dual mono file I can still have the option to pan left or right (or delete one side) as I wish. Also, using the process I described above allows you to have two completely separate mono tracks in the left and right sides. (Not that I'm doing it with this particular project.)
Old 06-21-2021, 03:42 PM
Thanks .................Dave : )
I tried CTL+M with no luck, I know Pro Tools | First is limited to make me upgrade so I'm not sure if that's a missing feature. Either way, I selected the track in question, clicked CTL+M and nothing noteworthy happened.
As for the output, it's the same as all other tracks (including one that I recorded and "dual monoed" the exact same way). All of those other tracks are monitoring properly.
What's troubling me is that I did the process once, then repeated it exactly and got different results.
Old 06-21-2021, 04:15 PM
But you have a pan control on a mono track to move the signal to the left or right side of your stereo spectrum. There is no reason to have a stereo track. You’re doing the exact same thing via a convoluted process.
Do you mean two different audio tracks on the left and right channel? As in say two passes of a guitar track? Again, there’s no need to go through the process of what you’re doing. You use two mono tracks and pan one hard left and one hard right. The result is the same thing you’re doing albeit without the lengthy work around.
Old 06-21-2021, 07:26 PM
Yes. Pro Tools First only allows a max of 16 tracks, and as far as I can tell it doesn't discriminate between mono and stereo tracks, so in essence you can "steal" extra tracks. Like the 2 guitar passes you mentioned. Or a kick drum on one channel and a snare on the other, for example.
As I mentioned at the top, I'm a PTF newbie, so I'm learning its possibilities and limits as I go.
Old 06-21-2021, 11:25 PM
JFreak's Avatar
JFreak JFreak is offline
I'm learning
First thing is to learn keeping it simple. Learn tricks once you hit the wall.
Janne
Old 06-22-2021, 02:02 AM
If that’s why you’re doing it, I’d strongly suggest either paying for the full version of PT or switch to a less expensive and full featured alternative DAW.
Heck, just use Reaper. You won’t be hamstrung by those limits. Wait til you want to start using plugins and run j to those limitations with PT First.
Newly Created Stereo Busses not Accessible for Input on Audio Tracks EVaschon Pro Tools 2020 1 09-07-2020 05:18 PM
Sound on one track silenced even though wave form is visible! briaboy Pro Tools 12 2 02-12-2017 03:17 PM
Predefined Inserts on Every Newly Created Track? Typhoon859 macOS 3 11-09-2013 02:48 AM
Can't open Pro Tools in a newly created user account ritaM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-31-2008 09:16 PM
newly created tracks defaulting to a certain out lagasus Pro Tools TDM Systems (Mac) 2 04-18-2002 12:29 AM
