PT7.4.2pr with DIGI003 on leopard do not work for me
I've Install the Mac OSX 10.5.3 on my 2x2.8GHz Quad MacPro system and then PT 7.4.2pr with my DIGI003 Rack (Factory)
1. I do not have a succesfully installation: from the log file: 06.06.08 17:55:51 pkgExtractor[351] BomFileError 13: Permission denied - ///Library/Application Support/Digidesign/Plug-Ins/Chorus.dpm 06.06.08 17:55:51 pkgExtractor[351] pkgExtractor exited with error 1 while processing package '/Volumes/Pro Tools LE Installer/Install Pro Tools LE.mpkg/Contents/Packages/DigiRack Plug-Ins.pkg/Contents/Archive.pax.gz' 06.06.08 17:55:51 Installer[316] Install failed: Le programme d’installation n’a pas pu installer certains fichiers dans «*/*». Contactez l’éditeur du logiciel pour obtenir de l’aide. After the reboot: 06.06.08 17:56:15 SystemStarter[17] "/Library/StartupItems" failed sanity check: path was created after boot up 06.06.08 17:57:12 com.apple.launchctl.System[2] launchctl: Dubious permissions on file (skipping): /Library/LaunchDaemons/com.digidesign.fwfamily.helper.plist 06.06.08 17:57:31 SystemStarter[18] "/Library/StartupItems/Digidesign Mbox 2" failed security check: group writable 06.06.08 17:57:31 SystemStarter[18] "/Library/StartupItems/Digidesign Mbox 2" failed security check: not owned by UID 0 06.06.08 17:57:31 SystemStarter[18] "/Library/StartupItems/Digidesign Mbox 2" failed security check: not owned by GID 0 06.06.08 17:57:31 com.apple.SystemStarter[18] -s Starting WD MyBook Services 06.06.08 17:57:31 SystemStarter[18] "/Library/StartupItems/DigidesignLoader" failed security check: group writable 06.06.08 17:57:31 com.apple.SystemStarter[18] PACESupport - launchd already started us 06.06.08 17:57:31 SystemStarter[18] "/Library/StartupItems/DigidesignLoader" failed security check: not owned by UID 0 06.06.08 17:57:31 SystemStarter[18] "/Library/StartupItems/DigidesignLoader" failed security check: not owned by GID 0 06.06.08 17:57:33 mds[23] (/Volumes/Backup/.Spotlight-V100/Store-V1/Stores/07E1EFAA-DB8A-491F-83EA-E05912673111)(Error) IndexCI in ContentIndexOpenBulk:Could not open /Volumes/Backup/.Spotlight-V100/Store-V1/Stores/07E1EFAA-DB8A-491F-83EA-E05912673111/live.0.; needs recovery I do not have an MBox 2 and never had one connect to my system!!! Then I can start protools ans can see the Digi003 interface in it, but cannot create a new project or open the PT demo. I got the error message: This session is saved on a volume set to *Transfer" only. ... When I open the Workspace, I can only see a "Paused" Listening Workspace, You do not have appropriate access. Even a clean de-installation has not helped Do you have any suggestion to help solve this problem? Thanks mitch PS: got Time machine running on my system but if I disable it, it doesn't solve the problem |
Re: PT7.4.2pr with DIGI003 on leopard do not work for me
I reset the permission using the Disk Utility, but has no effect.
I also have a similar problem with the Pro Tools Beta on Leopard 10.5.3.
My internal drive of my new Imac doesn't show up in the Workspace-window, and I get the "You do not have appropriate access" error. Can't record or play anything back!! I'm using the digi 002 interface. Tech-support pleeease!!? |
A few things to consider,
1. Have you checked drive Ownership and Permissions using Finder (Apple 'I')? What about installing from a new Administrator account? 2. Do a clean unintall and reinstall one component at a time. That is, uncheck everything except PT (no plug-ins). Install, clear Prefs/DDB's and reboot. Next just plug-ins etc. 2. You might have to reformat the HD's with Mac extended journaled (NB it will erase the drive contents). http://www.myspace.com/philogg |
PT LE doesn't work with Snow Leopard ! | supermarco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-05-2009 05:03 PM |
hardware recommendations for getting a MBPro to work with DIGI003 | wishesonaplane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 05-05-2009 05:23 AM |
Do UA TDM plugs work with Leopard? | IO Composer | Pro Tools TDM Systems (Mac) | 12 | 01-13-2009 11:56 AM |
Possible to get Digi003 to work with iTunes? | toddamo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-20-2008 09:23 AM |
Leopard and 7.4 Work! | RussUK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-17-2008 06:01 PM |
