Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 06-19-2023, 04:36 PM
andymixer andymixer is offline
Default Carbon Overheating Message
Hello everyone,
This afternoon I just installed Pro Tools 2023.6 and after working for about an hour I received this message I've never seen before:
"The Pro Tools Carbon 2396 interface internal temperature is higher than expected, which could result in overheating. The device may need to be serviced." [see attached screenshot]
I've had my Carbon for over a year and never had a message like this nor any issues with the unit being to hot. Should I be worried?
Anyone else have any light to shed on this matter?
Old 06-20-2023, 08:42 AM
dominicperry dominicperry is offline
Default Re: Carbon Overheating Message
I've never seen this, and Avid assured me that before they changed the firmware to reduce the fan speed (which happened a long while back) that they had tested with the reduced fan speed and with multiple Carbons all in a rack on top of each other, and they were fine. So this implies to me that either a sensor has gone wrong, the fan has failed or you've blocked up the vents. Or it's too hot in your studio.
I'd start a case with Avid, you don't want to cook the box.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 06-20-2023, 08:56 AM
Thanks Dominic. A little later I restarted Pro Tools and ran a session for about 3 hours and never saw the message again. Guess I'll wait and see if it happens again.
Old 06-24-2023, 03:00 PM
makeller makeller is offline
I built a custom cabinet for my Carbon and noticed that it was running quite hot. I ended up buying an 80mm 5v Noctua fan and a Noctua fan controller to draw air out of the Carbon. I connected with Velcro. I run the fan slow but I can feel the warm air coming out, which I'm always happy about! Good 45$ spend
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? pm mastering studio Pro Tools | Carbon 0 12-22-2022 01:54 AM
HDX overheating? AE Pro Tools HDX & HD Native Systems (Mac) 3 07-07-2013 12:41 PM
CPU keeps overheating, more RAM? mastershredder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-23-2006 03:04 AM
Sync I/O Overheating? Florian Pro Tools TDM Systems (Mac) 1 04-25-2003 12:36 AM
