Custom Soft Key Issue with 5ms Delay
Hey guys, I'm trying to create a custom softkey on my S6 that performs the following function...
recalls a memory location that has a selection stored, then performs the "clear all automation" command. It only works about every tenth time I press the button, which I figure means that it needs some delay in order to work properly. However, I have inserted the special key marked "5ms delay" multiple times in the sequence and it seems to not be working. I know this because I can pull up the Text Edit app and see that the characters are coming out at the exact same speed with or without the multiple 5ms delays programmed in. As far as I can tell, the 5ms delay special key simply does not work. Am I missing something here? |
Re: Custom Soft Key Issue with 5ms Delay
I don't have an S6 but on a system 5 MC, 5 ms wouldn't be enough. I mostly use
100 to 200 ms pause in between each steps when programming soft keys. I hope that help!
Serge Hamel Mixer / Sound Designer http://www.netpostproduction.com http://immersivesoundvr.com/ |
Tips for moving custom user sets/soft keys to a new computer? | mrsquid | Artist Series | 1 | 04-04-2013 02:37 PM |
Protools/Icon crashes when I hit Custom Fader soft key | NYCaudioconnection | ICON & C|24 | 8 | 11-12-2007 07:18 AM |
Soft Synth Delay Compensation Steps | Delta Dreams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-08-2007 05:20 PM |
Soft Synths and Delay Compensation | michael c | Pro Tools TDM Systems (Mac) | 1 | 02-20-2006 10:22 AM |
midi delay and soft synths | soosh | Digidesign Hardware & Software | 1 | 01-24-2001 07:24 PM |
