Old 04-10-2009, 09:35 AM
mike1234 mike1234 is offline
Default Built in sounds in midi keyboard
I am wondering if it is possible if I can set pro tools to record from the sounds which are built into my midi keyboard.
I have figured out the way to record sounds using virtual instruments.
However, I'd like to use some of the built in sounds in my midi keyboard.
Is this possible and does anybody know how to do this?
It would be a great help.
Thanks.
Old 04-10-2009, 10:07 AM
gdugan gdugan is offline
Default Re: Built in sounds in midi keyboard
Plug the audio outputs of your keyboard into the audio inputs of your interface (MBox, 003, etc.). Create an audio track, assign its inputs to the inputs of your interface, and record. See page 357 of the Pro Tools 8 Reference Guide.
Old 04-10-2009, 10:28 AM
Is this possible with the Mbox 2 mini.
I have connected my keyboard connected by an edirol usb midi interface.
There is only Line/DI inputs and an XLR jack on the mbox 2 mini
Old 04-10-2009, 01:33 PM
barstool719 barstool719 is offline
if you only have 1 input, just record it mono.
audio out of keyboard > 1/4" cable > mbox mini
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 04-10-2009, 04:57 PM
Amin7b5 Amin7b5 is offline
The Mini has two 1/4" inputs anyway, so why not:
keyboard stereo out -> two 1/4" cables -> input 1&2 of the Mini -> Pro Tools stereo track
If you are sequencing in pro tools then route the midi data to the keyboard, and record the subsequent audio back through the Mini.
MIDI keyboard doesn't trigger sounds on time staylow Pro Tools M-Powered (Win) 3 11-30-2010 06:17 PM
Recording drums sounds using MIDI keyboard. songwriter1 MIDI 0 02-07-2009 01:31 PM
Assigning MIDI sounds to MIDI controller and playing sounds with MIDI lalalandguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-02-2009 12:52 PM
One midi keyboard to trigger two sounds or more? K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-27-2006 01:16 AM
a keyboard with a jog wheel built in WorldOfWiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-10-2003 10:44 AM
