problem with edit window display
When I try to maximize the edit window it does extend all the way out the right side so I can't get to the grid pull down menu and adjust the spacing and snap. I've tried resizing it manualy and changing my display settings but nothing has worked. Can anybody help me out? This is very frustrating. Is there another way to adjust the grid spacing/snap other than the pull down menu in the very upper right hand side? thanks spencer |
Re: problem with edit window display
Yeah, Spencer, you can adjust the Grid by hitting Alt./Start and hitting + or -.
The 'Start' key should be the second one to the right of your Alt. key. To change your Nudge note, hit Alt./Ctl. and hit + or - Then to Nudge, highlight the area, and just hit + or - Hope that helps, Roy
rh music |
Change your screen resolution to 1024x768 or more.
External Display for Mix/Edit window | rakprachow | Windows | 2 | 10-26-2011 09:34 PM |
Edit Window Display problem... | Benjamino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-09-2010 11:03 AM |
Edit Window Display; and Elapsed Time | Mike Harrison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-18-2006 05:54 PM |
Midi edit window display ? | Eddie K. wannabe | MIDI | 0 | 05-03-2003 07:58 PM |
Edit Window Display not completely visible | Douglas Audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-26-2002 10:14 AM |
