Old 10-27-2011, 04:33 AM
BobRogers BobRogers is offline
Default Opening PT9 sessions in PT10
So to all of you early adopters out there - have you had any problems converting PT9 sessions to PT 10? I've been putting off making a final decision on the buy/skip question until I finish a CD I'm working on. Should that be a consideration? Have you noticed any glitches?
Old 10-27-2011, 04:36 AM
Stiff Stiff is offline
Default Re: Opening PT9 sessions in PT10
I've opened 5-7 sessions. They all work fine. Takes a little extra time to open the first time because of waveform calculations but after that there's no problem. When you save, Pro Tools will ask you to save in .ptx-format.
Daily news & reviews
www.ProToolerBlog.com
Old 10-28-2011, 04:16 AM
rofa rofa is offline
What about the other way round? If I'd work in PT10 and have to take the stuff to somebody who works with PT9, can it be exported or "saved as..." in ver 9 format (somewhat easily)?
Edit: Never mind, I found the answer in the PDF "what's new". There's a save sesion copy as... function for that.
Edit2: ...However, the edit clib group files can not be downgraded to work with versions lower than 10...
Bug in PT10 opening large sessions? derF macOS 2 05-25-2012 12:18 AM
Trouble opening PT10 sessions from editor. legasafe Post - Surround - Video 2 03-13-2012 02:45 AM
PT10 crashes when opening sessions Legion6789 Pro Tools 10 8 12-28-2011 02:11 PM
GR5 not opening in PT10 kstrube macOS 0 10-26-2011 01:09 PM
Opening LE 7 sessions on LE 6.1 model.citizen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-16-2006 09:04 PM
