Originally Posted by Bill Denton
For starters...
The mac address does NOT change! It is hard-coded into the hardware. Further, no two pieces of equipment will ever have the same mac address!
I've seen a lot of switches, and none of them has ever provided DHCP. That doesn't mean that none of them ever have, but it's highly unlikely yours does.
Turn on the DHCP server on your router.
If any of your equipment must have a static IP address, make sure you exclude these static addresses from the DHCP pool.
Connect your switch to your router.
Turn on the DHCP client on your computer, connect it to your switch, and make sure all is working properly.
Turn on the DHCP client on one of your Euphonix units, connect it to your switch, and make sure all is working properly.
Do this for each of your Euphonix units, one at a time.
Everything should work okay after that...
No need to yell. Mac address do not change.
OK now I know!
Thanks for the tips but I said I fixed my problem in my previous post.
