Old 07-20-2021, 03:36 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Default Re: 32bit or 24bit
I aim at -10 with the classic PT metering. Unlike analog, the error is having the levels too high as opposed to too low which was the classic problem with tape.
It took me a few years to get that notion through my head. What finally brought it home was a friend who was having trouble getting his levels up using his new 001. His mixes that were peaking at -40 sounded way better than my clients who had mixed on an SSL with all high-end gear.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 07-21-2021, 07:04 AM
arche3's Avatar
arche3 arche3 is offline
24bit, 44.1. Don't record too loud.. Make music. Don't worry about it.
Sent from my SM-G986U using Tapatalk
Old 07-21-2021, 12:30 PM
noobstudioguy noobstudioguy is offline
Originally Posted by unkJE View Post
And for Editing - record at 32-bit float for the joy of Clip Gain
Bounce/print to whatever’s required
BTW - welcome to the DUC – best “First Thread/Post” in a long while:
"Save Copy In" full explanation - https://duc.avid.com/showthread.php?t=416173
For a great way to search the DUC, before posting:
Type (any topic – site:duc.avid.com) in the URL space
For example:
32-bit float in Pro Tools - site: duc.avid.com
I couldn't help myself and kept on reading up on this subject. Making way more sense now.
I think I have one final question. For the joy of clip gain, what did you mean by this? I am familiar with clip gain (the basic clip gain function in every daw which is used for gain staging / turning down audio PRE fader) but how would that be an advantage when tracking?
Apollo Twin X Thunderbolt, Ryzen 9 3950X, Gigabyte B550 Vision D MB, Seagate FireCuda 520 1TB M.2-2280 NVME SSD, MSI GeForce GTX 1060 6GB Video Card, Slate Digital ML-1, Kaotica Eyeball, Nektar Impact LX88, PreSonus HP4, Beyerdynamic DT 990 Pro 250 OHM, KRK Systems ROKIT 6,
Old 07-21-2021, 04:42 PM
unkJE's Avatar
unkJE unkJE is online now
Originally Posted by noobstudioguy View Post
… I think I have one final question. For the joy of clip gain, what did you mean by this? I am familiar with clip gain (the basic clip gain function in every daw which is used for gain staging / turning down audio PRE fader) but how would that be an advantage when tracking?
I was talking about Editing, not Tracking:
I guess the joy started with Pro Tools 10 HD’s ability to convert clip gain to volume automation – but the day-to-day joy (when Editing) is zooming in and adding Clip Gain breakpoints on either side of a Transient (or a selection) – then using the ensuing Fader to either lower or raise the volume – create Crossfades, then consolidating … making adjustments so easy and quick!
See:
Pro Tools Shortcuts p.21 - Chapter 5 - Edit Window and Mix Window Keyboard Shortcuts – Clip Gain
Clip Gain Line & Clip Gain Info
https://www.protoolstraining.com/blo...pro-tools.html
Pro Tools® 10 ‒ Clip Gain Overview ‒ Avid
https://youtu.be/B9VEK3LcDZg
Crossfades:
https://www.sweetwater.com/sweetcare...-in-pro-tools/
Old 07-22-2021, 01:57 AM
See:
Crossfades:
Gotcha, but how is clip gain better with 32 bit float?
Old 07-22-2021, 09:27 AM
blackmacdaddy blackmacdaddy is offline
<<Why is 32-bit better for clip gain?>>
32-bit 'float' is better because it has the ability to represent up to 1528 dB of Amplitude – way more than needed (earth's limit is around 210 dB from a 'blast wave')
So if a file clips (due to your input level to the 32-bit A to D) on tracking, you can actually 'pull it down with clip gain/AudioSuite' and eliminate the distortion.
And as Bob and JFreak mentioned above:
32 won't be able to remove distortion from your analog chain
32 won't be able to remove distortion from an overloaded 24-bit converter
32 will be better for 'file based processing' and 'printing out' Virtual Instruments
Here is a good explaination:
https://www.sounddevices.com/32-bit-...les-explained/
It's only R'n'R but I like it.
Old 07-22-2021, 10:32 AM
My 2 cents worth:
1-I record at 24 bit/48K. Why 48? It pushes the high frequency limit a bit higher, which also pushes the phase shift of the filter higher. Not saying I can hear the frequency difference, but the reduced phase shift makes the top end just nicer(certainly a subjective comment).
2-Re levels, Bob's suggestion to take -10 as the new "zero" makes a lot of sense. When I got started in PT(version 6), I made 2 mistakes early on; I recorded things too hot, and I rarely used a Master track(I figured since it was going out to be mastered, why should I use one). Needless to say, my early mixes sounded a bit crunchy. As soon as I added a Master track, that clipping was easily seen and corrected.
3-Since I'm a creature of habit(including some bad ones), my fix for tracks which are too hot was(still is) to insert the TRIM plugin in the last slot of all audio and instrument tracks, set to -8 and all in bypass while tracking. When I get to the mixing stage, I enable all the trim plugins with a single command(some trim plugins will be edited or bypassed as a mix progresses). That makes the entire mix drop in level, but keeps the relative mix intact so I'm not starting from scratch. Some are probably wondering why trim goes in the last slot instead of the first and the answer is simple. Putting it first will change how every other plugin on a track is driven. Putting it last changes nothing but the final volume. Also, if I need to raise or lower a track that has lots of automation rides, adjusting the trim plugin level makes for a simple and quick overall tweak. Trim is built into all my session templates and track presets
Food for thought
Old 07-22-2021, 11:49 AM
paul_g's Avatar
paul_g paul_g is offline
A bit of levity - You will spend hundreds of hours on a mix, make pain staking decisions of different compressors, and effects and eq. Loads of time spent deciding 24bit, 32bit, 44k, 48 etc...
Send the song to your friends and post it on a public cloud offering and 99.9% of listeners will play it through crappy speakers on their mobile device, or earbuds.
Long gone are the days where someone enters a dedicated music library in their house, turns on their NAD receiver connected to the most expensive speakers, takes a snifter of brandy and sits back and enjoys a record from cover to cover.
As others have said; 24bit/ 44k, and make music and enjoy it. Remember anyone over 40 years old and beyond will not hear anything beyond 8k anyway. And the under 40's will just play stuff on their mobile devices.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 07-22-2021, 12:58 PM
Can't say I'd go that far. I can certainly hear way beyond 8K, as can most folks in my age group(over 60). Another reason I use 48K is because most video uses 48K audio(and most stuff I work on ends up on youtube at some point). I will agree with you on no song ever became a hit based on any of this tech stuff, or because of a mic, preamp, console, etc. It starts with a catchy song and a solid(or amazing) performance. The recording/mixing side mostly needs to not ruin it. I can't even count how many great hits were done with distortion, bad mix choices or outright mistakes
Old 07-24-2021, 10:58 AM
I can turn down a clipped vocal even if it was clipped during tracking, that is news to me. What if my converter is 24bit? Then 32bit isn't an option for me right?
Importing 24bit/48k into 32bit/48k session anackman Pro Tools 11 6 12-15-2014 03:56 PM
Recording: 24bit vs. 32bit float WombatStudio.Org Tips & Tricks 55 10-05-2014 03:41 PM
24Bit dithering in a 32Bit session. Any problems known? Franco1967 macOS 4 12-22-2011 12:50 AM
batch conversion 32bit to 24bit siga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-23-2007 04:51 PM
32bit.wav to 24bit sdII neuman Pro Tools TDM Systems (Mac) 0 05-08-2000 10:44 PM
