teeny tiny session cant playback
occasionally I am losing one track in a session..
there are only 12 sparse tracks so its not like a big strain on the system I have seperate system drive with vid on another drive, audio also on its own dedicated drive... tends to be a track I've recently recorded on.. native with 512 sample buffer - 90% processor any hints?
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive Focusrite Saffire PRO 40 Ultimate 2022 10 / HD Avid MC Mix / MC Control |
Re: teeny tiny session cant playback
Is it always the same track? If yes, the what plugins are on that track(and are all using the latest updates)? Since you are running at 512, you may as well go to 1024. Personally, I only need 2 buffer settings; Low and High
nope it tends to happen on a track I recording on... change tracks and it happens to that track too.
big buffer - good for big session right? small buffer - small session - and tracking..... only one EQ3 plugin in the session possible something to do with rewire? cos I'm usin that now... will be live recording soon - lets see if it crops up then oh yeah - just crashed changing buffer size....
jus upgraded my RAM from 4gb to now 16 gb
and this is still happening! ( several times and hour - sometimes right after each other.... getting bored of the make track inactive - make track active dance!!! ) there are no plug ins on the recording channel - an just an EQ 7 after the rewire plug in on the aux input., I bus to the tracks to record.. tends to happen after I drag in audio - or after editing on a different track an then want to record something disk buffer is now 4GB - the other buffer is maxed at 1024 - and I didnt use a delay compensation engine... over all the system says it has 8gig of unused RAM.. I have an SSD system drive ( bay 1 ) - record audio to its own drive -( bay 2 ) and run video from a 3rd drive... ( yep! bay 3 ) my audio SFX library resides on a 4th drive... ( bay 4 ) any help would be greatly appreciated!!
update - seems related to playback position...
now ( maybe not before?) if I move insert point to a different spot - say earlier 5-10 secs - then the track starts working again??!
its still irritating tho... any suggestions? ( B-u-m- p )
Have you tried importing the data into a new Session?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
these are new sessions... happening after using more than a couple of tracks..
I tried removin all the busses - apart from necessary - cos it was made from an avid supplied template... its happened on every PT session I ever had on this rig.. DP7 is runnin flawlessly ( i use it for a different TV series where I dont have to supply PT sessions for mixing) this is 16 mono channels at 48 k 16 bit
B- U - M - P
no one? memory has been upgraded.. ( now 16 gig ) was hopng that would solve it I tried runnin with my MC mix turned off. didnt solve.. its already bare min of plug in - ( would non loaded plug in affect? ) cheers
Delete prefs and databasses? What OS? What version of PT? CPU type? Audio drive type? Did it ever work?
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Teeny tiny bug in PT11 | remute | Pro Tools 11 | 0 | 07-29-2013 01:03 PM |
9128 error with tiny session...HELP! :) | songwritersoul | Pro Tools TDM Systems (Win) | 7 | 02-03-2012 07:56 AM |
Tiny MIDI playback breakups | myptf | Digidesign Hardware & Software | 2 | 09-23-2002 07:28 AM |
Pro Tools Teeny tiny fonts | Ke productions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-13-2001 02:17 PM |
"Tiny Computer" | bennycon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-15-2001 08:46 AM |
