How to know an audio clip frame rate
I need to know the frame rate in which an audio clip was really recorded. I used a zoom f4 and I have chosen the frame rate in 24 fps but in fcp says that it is 23.98 and I want to verify it in pro tools but I don't find any information like this. Is there a way to know the fps of an audio clip in pro tools? Thank you so much! you're saving my life. |
Re: How to know an audio clip frame rate
Go to the "Windows" drop down menu in Pro Tools, and open Work Space.
You can view all information about an audio file (as well as video files, effects presets, Session files etc) in columns. Sent from my iPhone using Tapatalk |
Thank you so much for your help. I opened the workspace but in the column of tc rate doesn't appear any information. Any idea of why is this happening?
Audio has no framerate. This is just a setting in the metadata written by the recorder. Easiest way to read it is with Waveagent (which is free)
https://www.sounddevices.com/product...are/wave-agent |
Thank you so much! I'll check it out.
audio frame rate conversion | nardo | macOS | 2 | 08-16-2012 02:47 PM |
Frame rate audio clip converter | RuffinMedia | Post - Surround - Video | 3 | 07-04-2012 02:55 AM |
frame rate on audio file? | viaspiaggia | Post - Surround - Video | 19 | 07-28-2010 12:38 PM |
Audio Frame Rate NTSC to PAL | mattcmi | Pro Tools TDM Systems (Mac) | 3 | 05-25-2010 12:15 PM |
Free Frame Rate and Frame Calc widgets | dr sound | Post - Surround - Video | 1 | 08-21-2008 11:39 AM |
