Track Count, RTAS and Buffer Size ...
Hi!
I was experimenting on using some number of plugins on roughly 6-9 test tracks on a G4 sawtooth 256 MB U-ATA 7200 drive. Recording 24 Bit 48 Khz. I used 128 samples as buffer size for recording and stayed on that level as I added effects. A number of stereo DVerbs, EQ, and Stereo Comps. Everything played back as it should. But, then I changed to a higher buffer size, 512 and 1024. Suddenly I couldn't play back due to "CPU overload" message. Why is that ? I thought having larger buffer sizes meant more processing for plugins ? Or is it that higher buffer settings introduce more load on the CPU for IDE drives ? Regards, // Joakim W ------------------ >>We need more time so that everything doesn't happen at once<<
Digi 002 Mbox 1 Digi001 (retired to shelf) Asus P5K Premium v3, Q6600, 2x2GB Corsair Tyan Thunder n3600B (S2927A2NRF) 2xAMD OPTERON 2214 2.2GHZ Win XP Pro SP3 |
Re: Track Count, RTAS and Buffer Size ...
Please also note:
When I changed back to 128 samples of buffer size, the session ran smoothly again. // Joakim W ------------------ >>We need more time so that everything doesn't happen at once<<
phobia,
This has been observed by other G4 owners (including myself). My advice: leave the buffer at 128 and count your blessings! If you search the older threads you will find more info about plug-in count vs buffer settings. Good luck, Jeff D. |
Yep, I'm in the same boat. G4 and I get more plugins with 128 than 1024. Don't know why, but I'm not complaining.
------------------ LW
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Ok, has Digi had any explanations on these findings. It feels a bit worrying not knowing why your HW/SW doesn't behave the way you expect it to.
I was having the same phenomenon on my G4, but after doing several different types of projects, I have found a few circumstances when raising the buffer size improved my performance:
-A session with a lot of plug-ins (Waves and others) was creating pops in the audio at 128. Raising it to 256 solved the problem. -Running PT alongside a virtual synth ruined the playback audio at 128. Raising the buffer to 512 not only cleared up the audio, but even allowed (turtle-like) metering while recording a track of the synth. This is on my Yikes G4/350 w/256 Mb RAM. So it seems that when the system is actually against the wall, raising the buffer can create a little headroom. Otherwise, I just run at 128. Hope this helps. |
Well I guess I just stick to 128 samples as long as it will go.
I pity though if I really need some more power and raising tha buffer size gets the opposite effect. Really would like to know why, just hate in when a piece of equipment behaves in a certain way I don't have control over. Thanks, // Joakim W ------------------ >>We need more time so that everything doesn't happen at once<<
Problem with H/W Buffer Size and RTAS | yunberzerk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-15-2012 02:51 PM |
CPU (RTAS) and Buffer Size Issues with PT9... | jmac146 | Windows | 10 | 09-12-2011 05:37 PM |
8meg drive buffer=higher track count?? | Nitronick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-17-2003 11:32 PM |
-9092 error when recording single audio track w/ lower than 4096 HW buffer size | Jeff Sloan | Digidesign Hardware & Software | 2 | 12-12-2002 08:38 AM |
Weird noise when playing back vocal track with buffer size under 1000 | mixmasterc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-05-2002 08:15 AM |
