Bad analog input on 192..I think, help please
I need some advice.
I just bought a used 192 of ebay. Of course the listing said gently used.:roll eyes: Anyway I plug it in and for the first 15 minutes it's on the fan is quite loud and then it quiets down. I can live with that but analog input 7 flickers all by itself, and makes blasts of white noise, so as that input is unusable. Is this something that can be fixed by pulling the input card out and reseating or is the input card hosed? Or could it be the digi cable going from the pcie card to the 192? I haven't called the seller yet, not looking forward to it. |
Re: Bad analog input on 192..I think, help please
sounds like some bad ICs on the ADC board, will need to be sent in to be fixed
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Thanks guys, I'll pull it out anyway, maybe compressed air and such will help?
Peace! |
Any idea what the fan replacement for the 192 goes for?
Send it here
I get several a week from coast to coast Generally averaging $150-200 with same day repair and shipped back out the following day ( 50% less and faster than you know who ) Doubt the problem is caused by any IC as mentioned in a previous post Just contact me if you wish to get it fixed
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
So I don't know yet if he'll pay for it. He thinks something happened in shipping but a bad fan and the ad card? I've reseated the ribbon cable on the card but it didn't help. So I'd just ship the card to you I assume? should I replace the fan, even though it's still working but sounds sort of like it has a cold ;-) I guess it's covered under ebay's protection plan so hopefully someone other than me will pay to get it fixed! Thanks! I'll give you a call. |
I repair these cards daily and Believe it or not the cards get incredibly hot normally.
When the cards are repaired on the bench, or the 192 is run with the top off the fan becomes a non factor, and the cards function fine So unless the fan is dead, or the location where unit is located is hot Heat normally does not create a problem, unless it's over a extended period of time, Its unlikely that a functioning FAN problem will cause any " noise problems " on a IO card, I also have fans in stock because sometimes they are to loud for a location or dead, I can replace it also or just ship one to you I'll be more than happy to fix the card ASAP Just call or email me via my webpage or address below Thanks
Digidesign 192 Analog Input Card and Analog output Card for Sale | MusicEngineer | Buy & Sell | 1 | 03-03-2014 09:03 AM |
Aux Input vs. Mic 1/Analog 1 Input (when using external preamp) | xesands | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-26-2010 08:27 AM |
192 Analog Input Input Problem, Very Frustrating | lenkarm | Pro Tools TDM Systems (Mac) | 7 | 04-20-2010 09:27 PM |
888/24 noise on analog input | rantanplan | Digidesign Hardware & Software | 1 | 01-20-2005 12:05 PM |
192 I/O Clicks on 2nd analog input | shakti | Pro Tools TDM Systems (Mac) | 2 | 11-18-2004 06:02 AM |
