Noob Just Getting Started - update 9.01 won't start now
PT9 working on laptop fine - then I updated to 9.01 - also
Mbox_2_Driver_v90_69594.dmg MIDI_IO_Driver_v90_69602.dmg now startup fails with below.... did the mbox & midi drivers mess something up? Process: Pro Tools [671] Path: /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: ??? (???) Code Type: X86 (Native) Parent Process: launchd [425] Date/Time: 2011-01-14 14:04:42.118 -0800 OS Version: Mac OS X 10.6.5 (10H574) Report Version: 6 Interval Since Last Report: 2081760 sec Crashes Since Last Report: 1219 Per-App Crashes Since Last Report: 5 Anonymous UUID: 250CE906-EBDC-40A6-A018-A70E61088A41 Exception Type: EXC_BREAKPOINT (SIGTRAP) Exception Codes: 0x0000000000000002, 0x0000000000000000 Crashed Thread: 0 Dyld Error Message: Library not loaded: @executable_path/../Frameworks/CFnd.framework/Versions/A/CFnd Referenced from: /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Reason: Incompatible library version: Pro Tools requires version 9.0.1 or later, but CFnd provides version 9.0.0 Binary Images: 0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld Model: MacBookPro6,2, BootROM MBP61.0057.B0C, 2 processors, Intel Core i5, 2.53 GHz, 4 GB, SMC 1.58f15 Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 256 MB Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB Memory Module: global_name AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.10.131.36.1) Bluetooth: Version 2.3.8f7, 2 service, 12 devices, 1 incoming serial ports Network Service: AirPort, AirPort, en1 Serial ATA Device: Hitachi HTS545050B9SA02, 465.76 GB Serial ATA Device: MAT[bleep][bleep][bleep][bleep]ADVD-R UJ-898 USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfd100000 USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0xfd120000 USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0xfd110000 USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfa100000 USB Device: iLok, 0x088e, 0x5036, 0xfa140000 USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0236, 0xfa120000 USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8218, 0xfa113000 USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0xfa130000 |
Re: Noob Just Getting Started - update 9.01 won't start now
OK - fixed ... reinstalling the 901 update fixed it - I guess the mbox & midi drivers messed it up with v9.0 ...
NEW PROBLEM : NO SOUND OUTPUT for MBP with no interface ...
in mixer i am not able to choose master 1 outputs = a1-2 - path n/a so grays out - how do I fix this in setup i/o? |
solved - i set playback engine to internal to built in output
Noob Just Getting Started - Need Tutorials | coolbro | Pro Tools 9 | 8 | 01-14-2011 02:40 PM |
Pro Tools Noob Start Up Help | Tman311 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-18-2010 10:38 AM |
I want to get started but dont know where to start. | soxoff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 06-17-2009 07:23 PM |
Update from 7.0 to 7.3 (noob) | neversleep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-22-2006 10:35 AM |
Do the regions store their start time (nOOb)? | M55ikael | Tips & Tricks | 1 | 09-03-2006 02:05 AM |
