003 Rack Analog Input Problem
Hey everybody,
I'm new to Pro Tools and this will be my first post. I set up my 003 rack and daisy chained a brand new glyph firewire hard drive, all according to the manuals. When I get into the recording environment and I try to select an input from the I/O menu, I only get interface 1 and 2 (mono). I'm missing 6 other inputs. I opened up logic and checked to see if all my inputs were available in logic and there was only 2 inputs available. I have no clue what this could be. Any help at all would be greatly appreciated. Thank you. |
Re: 003 Rack Analog Input Problem
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
That's the ticket. While you're there, spend some time learning about how the setup works and how you can customize it for you. For instance, you can rename the IO so if you keep certain mics or instruments assigned to certain inputs, naming them makes your workflow nicer. On my system, I have inputs named Motif, Roland TD10(for 4 line inputs), Fire 1, Fire 2 etc. for my firestudio inputs and phones 1, phones 2, etc for the outputs that feed my headphone amp.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
192 Analog Input Input Problem, Very Frustrating | lenkarm | Pro Tools TDM Systems (Mac) | 7 | 04-20-2010 09:27 PM |
Problem with the microphone input Digi 003 Rack | Flux06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-30-2008 01:11 PM |
Problem with S/PDIF input on 002 Rack | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 37 | 03-29-2007 07:33 AM |
Digi002 Rack Hardware Input Problem | clod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-04-2006 10:22 AM |
192 I/O Analog Input problem | LiveWire Remote Recorders | Pro Tools TDM Systems (Mac) | 4 | 12-29-2002 11:06 AM |
