Wierd MIX system Bus issue
Hi All,
I just revived a G4 Mac to put together a MIX system with. I am running a Mix Core, Mix Farm, and testing to see if DSP Farm right under that would help life. Anyways, I am experiencing a very interesting issue I never saw before when using these rigs. The internal bussing of the system has been dropping levels 12db lower. I would route a track down a bus to another track, and it would show up at the other track 12db less than the original track it is coming from. I thought it might be a jealousy issue since we upgraded to HD, however I can't figure out how to tell the TDM system that there's no hard feelings. Any ideas? Thanks |
Re: Wierd MIX system Bus issue
I wrangled with this a while ago, here is a link to the thread, good luck with it, i found it a very frustrating issue to say the least. bus levels changing
Thanks a bunch Madlo,
I'm going to test this and see if it helps me out as well. Although I am using a MIX Core, MIX Farm, and DSP Farm, (in that order) I guess if this is the problem, I'll resort to doing the MIX Core and 2 DSP Farms. Thanks again. |
wierd distortion issue | e_man | Pro Tools 9 | 2 | 04-18-2013 11:07 PM |
wierd tracking issue...please help!!! | epiphone10 | Pro Tools M-Powered (Mac) | 1 | 04-18-2010 11:12 AM |
Wierd Strike Issue | MLE | The Drum Room | 2 | 02-19-2010 03:18 PM |
Very wierd issue... HELP ! | timmyb2000 | Pro Tools TDM Systems (Mac) | 3 | 06-17-2009 08:50 PM |
Wierd MIX system Bus issue | faxbear | Pro Tools TDM Systems (Mac) | 0 | 09-05-2007 04:32 PM |
