Old 03-14-2008, 12:04 PM
dirtysoul dirtysoul is offline
Default Mbox loud static
I use an Mbox with a powerbook G4 1.6Mhz and Pro Tools LE 7.4cs3 and Logic Pro 8. I get this intermittent loud static on all outputs. Sometime it happend when i first start up and sometime i can go for a little while before it happens. Do you guys think it's a hardware thing?
Jerami
Old 03-14-2008, 01:11 PM
Phil Ogden Phil Ogden is offline
Default Re: Mbox loud static
You might want to try updating the firmware.
Random White Noise Bursts When Using Mbox
http://www.myspace.com/philogg
Old 03-14-2008, 06:42 PM
Thanks man I downloaded it and it seems to work OK. Unfortunately the issue is intermittent so I got to try all weekend. If I get no white noise in three days than I will be convinced! Thanks again man
Jerami
Latest Mbox Mini Random LOUD Static DMedic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-14-2010 07:21 PM
MBox 2 Mini Loud Static Problem. doug941 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 12-31-2008 02:15 PM
mbox loud static burst problem jlocke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-02-2006 04:03 PM
Random Loud Static Interferance Mbox/PTLE 7/Tiger yishai_k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2006 07:25 AM
LOUD Sporadic Static Noise on MBox taosound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-02-2006 10:39 AM
