Mtools and Protools 7.2 Incompatability
Hi all,
Having just upgraded our studios to 7.2, imagine our surprise when returning to a finished session and all our imported SFX from Mtools are missing from the session! Acording to Mtools, 7.2 has known issues with any file that is not directly imported (using the import audio fuction within Protools) into the session. So my question is this - is this true? Is there a work around? and is this issue getting fix ASAP? Going through and manually linking audio to the session EVERY time you open a session is not fun. Has anyone else had a similar problem? Thanks, David Liquid studios |
Re: Mtools and Protools 7.2 Incompatability
...no, but I'll be able confirm or deny in the next day or so as I cross that threshold.
Stay tuned. -scott |
it's what's being talked about at the mTools yahoo group.
no word on the fix yet. work around? record FX to 1/4" with address track and reassemble in PT. then they'll stay stuck. ok, sorry to be flip, i have consolidated my FX creating new files of them. doubles the space needed which can be a drag if it is a big file. but i guess we have to wait for a fix to come down.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Upgrade to SoundMiner. Better product. Much better support.
The problem in 7.2 is across the board for all products. The 'fix' needs to come from Digi. It is their bug. I wouldn't upgrade to 7.2 if using SM or Mtools is critical to your workflow. Stay with 7.1cs8 and you won't get this issue.
We are aware of the problem and a fix is being worked on.
charles maynes
charles maynes sound design and recording for film and media 818 618 0580 Member IATSE Local 700, MPSE, ATAS, NRA & USMCHC. |
D |
if you go to the Project Browser, select all you mTools loaded FX and then hit Copy and Relink, (from the little camera thing on the left), that is reasonably fast...
1) does that work 2) is that what you have been doing?
It works properly with SoundMiner. You just have to set your Soundminer preferences right. No issues.
protools and imac incompatability | glocke12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-19-2010 04:53 AM |
Wacom incompatability | KingTor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 07-12-2006 05:13 PM |
Logic 7 and Protools Mix Systems Incompatability | Ricky Pann | Pro Tools TDM Systems (Mac) | 4 | 12-05-2004 01:27 AM |
PT5 --> PT6 digirack Delay incompatability | Dopamine | Pro Tools TDM Systems (Mac) | 4 | 03-22-2004 07:08 AM |
Mtools and Protools | lionel payet | General Discussion | 20 | 01-08-2002 12:33 AM |
