Pro Tools LE 7.4cs3, Oxygen 8 v2, Powerbook G4 issues.......
i have a Powerbook G4 1.6Ghz with 2GB ram with Leopard 10.5.2. I use Pro Tools LE 7.4cs3, an Mbox, the original one, a M-Audio Oxygen 8 v2, and sometimes a M-Audio Midisport 2x2. I, for the life of me can't get my keyboard to trigger anything in Pro Tools. I know that "Pro Tools LE and Leopard are not compatible" yet but this was happening before I mad the switch. I tried everything, even deleting the Digidesign MIDI drivers cause I know there is a known issue. Anyone got any suggestions I am all ears.
Jerami Bellofatto [email protected] |
Re: Pro Tools LE 7.4cs3, Oxygen 8 v2, Powerbook G4 issues...
In Pro Tools go to Setup>MIDI> MIDI Studio Setup and click the "test setup" button does your Oxygen 8 display incoming signal present when you hit some keys ?(While plugged in USB, you will see the "in" arrow light-up blue for that device)
If NO, then there is something Oxygen 8 related having an issue. Maybe try creating a fresh and new MIDI Studio Setup Configuration.. If YES, then check the following settings in Pro Tools: Setup>MIDI>Input devices - Make sure the box is checked for your MIDI input device (OXY 8) Setup>MIDI>Input Filer - Record is set to "All" Options> MIDI Thru is "Checked" (in other words selected) Hope that helps!
If you don't have it backed up, do you really have it? [ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ] [ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ] |
I'll give it a shot after work, thanks
YOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!! It works! Hell Yeah
Pro Tools LE 7.4cs3 Update | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-01-2008 10:38 AM |
Pro Tools HD 7.4cs3 Update | Avid | Pro Tools TDM Systems (Mac) | 0 | 03-01-2008 10:28 AM |
Pro Tools LE 7.4cs3 Update for Mac OS X | peppertree | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-01-2008 07:06 AM |
Pro Tools HD 7.4cs3 Update for Mac OS X | K.I. | Pro Tools TDM Systems (Mac) | 0 | 03-01-2008 05:27 AM |
Oxygen 8 v2 & Mbox 2, connection issues | salcedodon | MIDI | 4 | 05-01-2006 01:56 PM |
