Pop/Clicks - ProTools LE 7.4 (Mbox) - Mac Pro....HELP!!!!
Whether tracking, mixing or just playback, randomly I will get a pop/click that will register clipping on my master fader and omitting a loud enough pop to make my voice students wince. I have the correct Core Audio drivers and OS. My MBox has the latest firmware and I have enough RAM to choke a small donkey. I am running through a Furman Power Conditioner and I can find no consistent rhyme or reason as to when or why this happens.
I have Synthogy's Ivory Pianos and the latest Reason. If I use them as a stand alone module, it happens there too. So, it's not ProTools specific. When listening to my MacPro audio, which is coming out of it's 1/8" front line-out...no pop/click. My Furman plugs directly into the wall socket. Should it be on a surge before plugging into the wall? I feel I have exhausted my options and would love any helpful hints regardless of how foolish they may sound. Best, Scott
ProTools 10 / Digi003 Control Surface / MacPro 8-Core (2, 3GHz Quad Intel Xeon) / 13GB RAM / Snow Leopard / Reason 5 & Record / Superior Drummer |
Re: Pop/Clicks - ProTools LE 7.4 (Mbox) - Mac Pro....HELP!!!!
Please start with the steps in the OS X Setup and General Troubleshooting sticky at the top of this forum.
You may want to look at the Help us help you thread as well. In other words - we need a lot more info. |
OK, done. I did everything that the "Setup and General Trouble Thooting" thread said to do including removing HEEELP from my subject line.
Let me provide some more info now. MacPro 2.66ghz Quad Core (2 internal SATA Drives) Tiger 10.4.9 6GB RAM ProTools Version 7.4 (Original MBOX) External Firewire Drive (For recording/playback) External USB Drive (not for ProTools) Pyro AV Link (plugged in USB but only on when being used, never when recording) That's my setup and I run the whole thing through a Mackie DFX-12 Analog Mixer into two Event monitors. Back to my issue, I get a really loud pop/click at odd times whether recording or playing back or using stand alone modules. I recently purchased Synthogy's Ivory Pianos. I bought a second internal SATA drive on which to put the sound libraries as they were initally on my Boot drive. Transfered the library the other day and pop/click still occurs. I have everything running through a Furman power conditioner. ProTools was reinstalled, I repaired disk permissions. Checked for faulty cables. Updated Mbox firmware. Newest PACE drivers and CoreAudio drivers. That's all the info I have and I'm still getting this nasty pop. It happens whether I use Ivory/Reason as a stand alone, or if I'm running PT. Loud enough to where it makes my students cringe.
I'm running the latest version for Reason & Ivory.
I use Ivory and Reason in every session that I create so I have tested a session without either.
Firewire 400 @ 7200RPM
As for your second statement - it's a little unclear. Have you tested this without Reason or Ivory in a session? If so, do the pops/clicks still occur? |
Reason 3.0.5
Ivory 1.0 with the latest stand alone and RTAS update which is 1.64 I have not tried a PT session without Reason & Ivory. But Ivory as a stand alone causes the pop too.
http://www.synthogy.com/pages/support/faq.html#Mac_A21 |
I was on the phone with Ilio's tech support just the other day regarding Ivory and my current issue.
I had the entire sample library on my Boot Drive. I told them I had a 2nd SATA drive in my MacPro and they told me to move the library to it. They said a second internal SATA drive is the "BEST" option to run Ivory. It even far surpasses an external Firewire option. I moved it, I repaired the disk permissions and made sure to delete the library from my boot drive. Still pops.
Protools HD 9.06 pops and clicks at 44.1 | Adam sachs | Pro Tools TDM Systems (Mac) | 0 | 02-04-2013 02:15 PM |
Protools LE8 and MBox2 - Pops and Clicks HELP! | Feghead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 11-18-2010 03:59 PM |
Random pops & clicks - Protools HD1 PLEASE HELP!! | bensampson | Pro Tools TDM Systems (Mac) | 2 | 03-12-2006 02:50 PM |
MBox pop/clicks | CharlieX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 01-17-2003 03:34 AM |
MBox Clicks **HELP PLEASE** | jnaz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-17-2002 10:59 PM |
