Audio Drop Outs on Some Channels
Hi Everyone,
I've been having a problem with Pro Tools for some time now regarding audio drop outs. It appears to happen to both audio and midi channels. Whats strange is it only happens to a one or two tracks specifically. The tracks that are effected is different between projects. When it happens I can hear a sustained noise in the background it sounds like a sine wave. When I stop playing or hit play again the noise goes away but the effected tracks no longer play. Restarting the session is a temporary fix but it keeps fruhstrating after doing it every 10 minutes. In one of the projects I can hear the auxilary channel which I use for reverb playing the Superior Drummer cymbals which are sent to it but I can't hear the cymbals going directly to the mains out. Is anybody else having the same problem and if so is there a solution? Cheers,
******* Pro Tools 12.4 | Focusrite Scarlett 6i6 | Gigabyte X79-UD3 | Intel i7 3820 2011 LGA | GeIL EVO Leggera 16GB 4x4GB | MSI Nvidia 970 | Corsair XT 850 watt PSU |
Re: Audio Drop Outs on Some Channels
I also had this same problem on my previous computer which was am AMD build
Hmmm, I've tried everything I could. Updating plugins, reducing background services and following optimization guides. I think the projects are struggling due to the amount of midi instruments and project data.
When I hit ctrl+alt+delete and check the memory useage it's well over 4GB. I hope a 64bit, software instrument friendly Pro Tools isn't far off.
Yeah, I've had symptoms like this before when using VI's that take up a lot of memory. I've gotten in the habit of bouncing down the instruments to audio tracks so the MIDI/Instrument tracks can be made inactive, which frees up resources (Processing/RAM). It's also a good habit to bounce them down so that you have that particular performance in a physical track form, in case you go to a DAW that doesn't have that plugin, or if you lose the plugin settings.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Yeah thanks a lot for the advice! It doesn't seem to take much for Pro Tools to start struggling. I bounced down most of the tracks leaving mostly audio and a couple of VIs but the problem persissted. Is there a faster way to bounce each track individually rather than soloing the track and waiting for it export from start to finish?
I have also hit the VI ceiling on occasion... You can easily use reaper to host all your VI's and wrap them into Pro Tools to make use of the 64 bit (virtually unlimited RAM storage and access) application. This will relive PT of the need to host the VI's and it should perform well.
Once PT goes 64 bit this wont be an issue. |
Reaper/rewire is a good alternative, though I personally still prefer to record the VI's to audio.
Great thanks a lot for your help guys. I'm going to try bounce all the tracks first and see if that helps.
I really enjoy working with Pro Tools which is why im so reluctant to move to another platform for composition.
Don't use bounce but the method cwsand mentioned. Much better and you'll see right away if something is amiss in the file being created as it shows in the Mix window.
HD 10 HDX Audio Drop outs | stanonbass | Pro Tools HDX & HD Native Systems (Mac) | 0 | 06-10-2013 01:42 PM |
Audio Drop Outs when PT is chasing LTC | LukeFromBerlin | Pro Tools TDM Systems (Mac) | 5 | 02-05-2012 11:54 PM |
HDX Audio drop outs on all HW Inserts | Carl Lie | Pro Tools 10 | 9 | 01-12-2012 03:52 PM |
ROSETTA 800 AUDIO DROP OUTS ANYONE? | jeffjuliano | Pro Tools TDM Systems (Mac) | 1 | 04-01-2005 10:17 AM |
Mystery Audio Drop Outs | cpunthank | Pro Tools TDM Systems (Mac) | 0 | 11-07-2003 04:17 PM |
