Old 12-27-2007, 07:36 PM
Edson Edson is offline
Default elastic audio problem
i am using elastic audio and when I stretch out a vocal using a warp function you can hear the location where the edit begins. Is there anything I can do about this?
Thanks,
Edson
www.myspace.com/kidboy
Old 12-28-2007, 04:28 AM
Ged Lineham Ged Lineham is offline
Default Re: elastic audio problem
You have to be careful where you're placing the line, how about zooming in on the waveform and picking a spot where tha audio is at it's lowest volume before your intended edit, it does work great but elastic is not an excuse for poor performance (ish) or lazy editing. Like everything, it has it's limitations. Good luck
Old 12-28-2007, 07:07 AM
Meko511 Meko511 is offline
your statement is very general: "you can hear where the edit begins" That can mean a lot of things. Do you mean the audio file is actually distorded from that point on? or is there a pop noise, / a click noise / or ???
Old 12-28-2007, 11:30 AM
Ok..to clarify...and expand on my original statement. I'm doubling some vocal lines and wanted to try out the elastic function by shorting the double to match the original by a little. The place where the warp market is creates like a pop or click noise after I shortened the section, which basicaly means I can't use the elastic function because I don't want a clicking noise. SO is there a way to go get rid of it? And if so how?
Thanks,
Edson
Old 12-28-2007, 12:12 PM
sinukus sinukus is offline
Are you using the Monophonic algorithm? You should be using it or Polyphonic for vocals.
Below Zero Beats on 92.7 FM San Francisco
Sundays 8pm - Midnight
http://belowzerobeats.com
Old 12-28-2007, 12:38 PM
The instruction manual says to you monophonic manual for vocals? What's the difference using polyphonic for vocals?
Old 12-28-2007, 12:47 PM
You can sometimes get good results with Poly on vocals depending on what you are doing.
Is there a region boundays at or need the warp marker? Sometimes these can cause pops.
It might be useful to get your session with just that vocal edit to see whats going on. Just warping internal to a region shouldn't cause a pop.
Old 12-28-2007, 12:50 PM
Vbhalla Vbhalla is offline
Did you try clicking on the elastic audio plugin on the track and adjusting the rate? that may help with the artifacting that you are hearing..
Vik
Old 12-28-2007, 12:55 PM
The Monophonic plug-in doesn't have any parameters.
Old 12-28-2007, 01:28 PM
yes . that is true..i was under the assumption that Edson is using the polyphonic setting...
Vik
Elastic Audio Problem LonestarBeatz Pro Tools 11 0 07-18-2013 07:56 PM
elastic audio problem edwallace Pro Tools 10 1 03-01-2013 09:21 AM
Yet ANOTHER problem, now with elastic audio, I can't be the only one! farmfresh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-17-2009 07:25 PM
Problem in Elastic Audio (LE 7.4) brentrains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-06-2009 09:24 AM
Elastic audio PT 8 problem gracec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-21-2009 08:50 AM
