Old 07-14-2022, 04:59 AM
garret garret is offline
Default 22.6 and deleting fades
Hey
Wonder is anyone else seeing this behaviour? Usually if a region has a fade out you can delete a portion of that fade and it shortens the fade to that length. Now it is simply deleting the fade entirely. Pretty annoying and slows things up considerably.
IMDB
Old 07-14-2022, 06:15 AM
IrelandM IrelandM is offline
Default Re: 22.6 and deleting fades
Hi garret,
Would you like to offer a little more detail on what you are trying to do and some context for others to reply.
Regards
Old 07-14-2022, 07:14 AM
Ben Jenssen's Avatar
I think Garret explained it quite well, actually.
Old 07-14-2022, 08:39 AM
Originally Posted by IrelandM View Post
Hi garret,
Regards
I'm not sure what other detail I could provide to make it any clearer? There is a fade on a clip. Previously you could select a portion of that fade and hit delete and the fade would change to that length. In 22.6 it is simply deleting the fade entirely. Just wondering if others are seeing the same.
IMDB
Old 07-14-2022, 09:49 AM
Hi garret,
Removing a portion of say a cross fade if the audio is separated causes it to cut the fade when removed just trying a test myself. If the fade is from the beginning the complete fade is removed and not shortened.
Just wonder if this has anything to do with separate at selection or the Batch Fades for audio in ProTools.
Regards
Old 07-14-2022, 10:50 AM
This is expected behavior(at least has been here for as long as I remember). To shorten or lengthen a fade, use the [ tool to edit the length. This is changing a fade, not deleting a portion of an existing fade. Selecting the clip with the entire fade and hitting delete is supposed to remove the fade. Sometimes, deleting a fade and re-doing it is the fastest method(I have done both methods and can't say I have a preference). Not sure if I explained that well, but hopefully I did
Old 07-14-2022, 11:51 AM
"Preserve fades when editing" tick box under preferences somehow got unticked. Problem solved
IMDB
Old 07-15-2022, 08:51 AM
18 years and still learning
HTML code is On
What am i missing here?! Fades and overlapped regions not deleting volkgti90 Pro Tools 12 4 12-06-2016 12:18 PM
Hotkey for deleting fades? jschmidtiii macOS 2 04-02-2013 10:55 PM
Deleting Fades in 6.7 Hostage Pro Tools TDM Systems (Mac) 3 11-11-2004 08:28 PM
Deleting fades GS-DK Pro Tools TDM Systems (Mac) 5 07-07-2003 04:45 AM
"Deleting Unused Fades" benderbro Pro Tools TDM Systems (Mac) 3 02-14-2003 10:59 AM
