Error while building SDK client wrapper
I'm unable to build PTSL client wrapper and PTSL CMD example application. The Python script stops at PyYAML. I'm on mac 13.6 (Ventura), Python 3.12.0 and Xcode 15.0 Here ist the Terminal Output: Code:
Collecting PyYAML==6.0 (from -r requirements.txt (line 20)) Using cached PyYAML-6.0.tar.gz (124 kB) Installing build dependencies ... done Getting requirements to build wheel ... error error: subprocess-exited-with-error × Getting requirements to build wheel did not run successfully. │ exit code: 1 ╰─> [54 lines of output] running egg_info writing lib/PyYAML.egg-info/PKG-INFO writing dependency_links to lib/PyYAML.egg-info/dependency_links.txt writing top-level names to lib/PyYAML.egg-info/top_level.txt Traceback (most recent call last): File "/Users/stefan/Desktop/PTSL_SDK_CPP.23.9.1.0.734915/Config/.venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module> main() File "/Users/stefan/Desktop/PTSL_SDK_CPP.23.9.1.0.734915/Config/.venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main json_out['return_val'] = hook(**hook_input['kwargs']) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/Users/stefan/Desktop/PTSL_SDK_CPP.23.9.1.0.734915/Config/.venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 118, in get_requires_for_build_wheel return hook(config_settings) ^^^^^^^^^^^^^^^^^^^^^ File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 355, in get_requires_for_build_wheel return self._get_build_requires(config_settings, requirements=['wheel']) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 325, in _get_build_requires self.run_setup() File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 341, in run_setup exec(code, locals()) File "<string>", line 288, in <module> File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/__init__.py", line 103, in setup return distutils.core.setup(**attrs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 185, in setup return run_commands(dist) ^^^^^^^^^^^^^^^^^^ File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 201, in run_commands dist.run_commands() File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands self.run_command(cmd) File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/dist.py", line 989, in run_command super().run_command(command) File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 988, in run_command cmd_obj.run() File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 318, in run self.find_sources() File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 326, in find_sources mm.run() File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 548, in run self.add_defaults() File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 586, in add_defaults sdist.add_defaults(self) File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/command/sdist.py", line 113, in add_defaults super().add_defaults() File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/sdist.py", line 251, in add_defaults self._add_defaults_ext() File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/sdist.py", line 336, in _add_defaults_ext self.filelist.extend(build_ext.get_source_files()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "<string>", line 204, in get_source_files File "/private/var/folders/q0/f0q3yzjx175cj7tpbs4zqrt40000gn/T/pip-build-env-p3esp5hv/overlay/lib/python3.12/site-packages/setuptools/_distutils/cmd.py", line 107, in __getattr__ raise AttributeError(attr) AttributeError: cython_sources [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. error: subprocess-exited-with-error × Getting requirements to build wheel did not run successfully. │ exit code: 1 ╰─> See above for output. note: This error originates from a subprocess, and is likely not a problem with pip. Traceback (most recent call last): File "/Users/stefan/Desktop/PTSL_SDK_CPP.23.9.1.0.734915/setup/build_cpp_ptsl_sdk.py", line 111, in <module> call_script(config_dir, source_dir, config, is_dev_mode_on, arch, os_version, bag_config_dir) File "/Users/stefan/Desktop/PTSL_SDK_CPP.23.9.1.0.734915/setup/build_cpp_ptsl_sdk.py", line 31, in call_script subprocess.run(cmd, cwd=cwd, shell=True, check=True) File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/subprocess.py", line 571, in run raise CalledProcessError(retcode, process.args, subprocess.CalledProcessError: Command 'source .venv/bin/activate && pip install -r requirements.txt && python "/Users/stefan/Desktop/PTSL_SDK_CPP.23.9.1.0.734915/Config/ptsl_build_script.py" --source_dir "/Users/stefan/Desktop/PTSL_SDK_CPP.23.9.1.0.734915/examples/ptslcmd" --config Debug ' returned non-zero exit status 1. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/Users/stefan/Desktop/PTSL_SDK_CPP.23.9.1.0.734915/setup/build_cpp_ptsl_sdk.py", line 113, in <module> shutil.rmtree(venv_path) File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/shutil.py", line 769, in rmtree _rmtree_safe_fd(fd, path, onexc) File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/shutil.py", line 674, in _rmtree_safe_fd _rmtree_safe_fd(dirfd, fullname, onexc) File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/shutil.py", line 674, in _rmtree_safe_fd _rmtree_safe_fd(dirfd, fullname, onexc) File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/shutil.py", line 680, in _rmtree_safe_fd onexc(os.rmdir, fullname, err) File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/shutil.py", line 678, in _rmtree_safe_fd os.rmdir(entry.name, dir_fd=topfd) OSError: [Errno 66] Directory not empty: 'site-packages' Any ideas? Thanks, Stefan |
Re: Error while building SDK client wrapper
an update:
fortunately, I had a Parallels VM with Monterey, Xcode 13 and Python 3.9 and I was able to compile the library there. It seems to be a problem with Xcode 15 and/or Python 3.12. |
Hi crustn,
We are pleased to hear that you have discovered a workaround. Have you had the opportunity to investigate this issue in the latest release (end of 2023)? It was addressed in that version. Please try to check. Regards, Artem |
I'm having the same issue building the client wrapper
Running iMac2020, Monterey 12.7.2, PTSL_SDK_CPP.2023.12.2.0.813759, Xcode 14.2, Python 3.12.1. I tried rolling back to Python 3.11 and got further with Conan loading. Now I get ERROR: PtslClient/None: 'settings.compiler' value not defined TIA |
Hi crustn, Ben,
Please see a reply with the suggested solution from Kenley in the other thread https://duc.avid.com/showthread.php?t=427322 Hope it helps you both. Thanks |
Mac Mini 2018, Monterey 12.7.2, Xcode 14.2, Python 3.12 PTSL 2023.12
-Evan |
Hi epm,
I wanted to let you know Ben has confirmed this issue is resolved in the other thread. The final resolution was to remove the default conan profile ~/.conan/profiles/default and run the build again once you've verified that Xcode command line tools are installed and selected. Here's a post with some more detail: https://duc.avid.com/showthread.php?...14#post2693914 |
compile PTSL client wrapper | Audio Editor | Pro Tools Scripting SDK Toolkit | 4 | 10-26-2023 03:21 PM |
Cannot compile the PTSL C++ Client Wrapper on Windows 11 | Loic | Pro Tools Scripting SDK Toolkit | 1 | 04-05-2023 02:19 PM |
How to uninstall PT12? Quicktime Wrapper error | QuacksMeUp | Pro Tools 12 | 4 | 11-01-2015 04:57 PM |
building new PC...windows install error | jonathan jetter | Pro Tools TDM Systems (Win) | 5 | 07-26-2008 05:31 AM |
Bounce Error! Please help, I have a client waitin | Hollens Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-19-2006 01:27 PM |
