Macbook Unibody + Pro Tools , HELP ME PLS
Maybe is a silly question for you all, but seriously i need your help.
im using Macbook unibody which lack of firewire state in Digidesign page - is not compatible to Pro Tools I will use it with Fast Track Pro Fast Track Pro come with USB port before this, is it lack of firewire then i cant use Pro Tools? Digidesign recommend record audio file tru firewire to external drive isit macbook unibody dont have firewire but they dont want us use USB external drive so they wrote is not compatible due to lack of firewire?? So why they still say that is compatible to PC or Windows Laptop all of them dont have firewire, but is compatible to Pro Tools? anyone can help me? Anyone using Macbook Unibody + Pro Tools 8 MP ??? Anyone know about this? Because i really want to use Pro Tools... I email Digidesign, but they never reply me. I would say a millions of Thanks if anyone can help me out. Appreciate it ! |
Re: Macbook Unibody + Pro Tools , HELP ME PLS
Macbook Unibody is a bad design IMO.
Can you return it and get an older one with proper connections?
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
They wont let you change. You using window + MP Pro tools?? |
You bought a unsupported machine not a lot anyone can do for you. You can use a USB external drive, but will only handle small sessions. If you have any problems then you kinda of hosed because it is a unsupported machine.
Don't feel bad many people make this mistake, they buy a computer then find out the system requirements for the software they want to use. In future pick software first get its system requirements then go computer shopping. BTW you can get Windows boxes with FW ports if you look around.
Steve B. ---------------------------------------------------------------- If you think you can or if you think you can't, you're right. |
Sell it to a friend, buy a supported model.
stop dreaming, man!
That is NOT going to happen. Quote:
The onyl reason other DAW like Cubase, Logic etc. don´t tell you what kind of equipment you need is becauase they don´t care about what Performance you get. AVID makes the at least an afford to tell you what performance you can expect from a certain setup. And they tell you that you won´t be satisfied with USB drive Performance.
last: PT11.3.1 |
is this ok?
Macbook white + FW 7200rpm external HDD + Mbox 2 It will work perfectly? =( i would like to know how you guys think about this. Thanks |
Here are your system requirements:
http://www.digidesign.com/index.cfm?...4&itemid=36933 It should be fine. By the way, have you already purchased the M-Powered software? If you have then it will NOT work with the Mbox 2! Mbox is strictly for ProTools LE. ProTools M-Powered REQUIRES an M-Powered interface. THEY ARE NOT INTERCHANGEABLE!! Your original post mentioned the Fast Track Pro, which WILL WORK with PT M-Powered and the MacBook White. Good luck!!
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
I will either downgrade to Macbook white or go for Macbook Pro. I still thinking bout, i should go for Mbox2 or Fast track pro+ m-powered pro tools. |
Macbook Unibody + Pro Tools - Help me PLS | musicery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 08-29-2009 08:10 PM |
Unibody MacBook Pro - both USB ports OK for audio? | Richard901 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2009 10:06 AM |
HELP: PT LE 8 on Macbook (unibody)... | AKGambino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-23-2009 07:49 AM |
PT LE 8 on Unibody MacBook for a week... | FreqSabotage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-14-2009 09:24 AM |
Unibody 17" Macbook Pro ? | plutone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-28-2009 12:52 PM |
