Old 03-04-2008, 02:27 PM
The Dougfather The Dougfather is offline
Default Can i save non defaut controller assignments for Xpand!
Hi all, i have a M-audio Oxygen 61 midi controller and i'm trying to map the rotary knobs to Xpand. I can map the defaults just fine using the m-audio enigma software, however when i assign a cc number for a non default it won't permanently save, is there any way i can get it to permanently stick.
For example rotary knobs 1 - 5 (Attack to Env Depth) no probs. Trying to map fine tune and level controls will not save. Is this a restriction of the plugin. I'm new to the mdii mapping so bare with me if i'm off the mark.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 03-04-2008, 02:58 PM
Default Re: Can i save non defaut controller assignments for Xpand!
Dougfather, I don't know about the Oxygen nor the Enigma software, but if you set the Xpand! Settings Perferences to Plug-In Default To>User Default and right-click>Assign respectively, then set as the user default, this should recall all user assigned CC mappings.
filosofem
Aaron Mulqueen - 001 HD Native
Old 03-05-2008, 09:33 AM
I knew there had to be a little menu hidden away, thanks filosofem.
Cheers
iCON Photography
Old 03-09-2008, 11:28 AM
Ok, heres what i did.
1) Assign a free midi cc value that is available to a parameter. An example, fine tune to cc76.
2) settings Preferences > Set plug-in default to > User setting
3) Select 'set as user default'.
After this when i change patch i lose the custom setting. It works fine for some parameters, the ones which have a cc value already assigned. For ones that don't, that i assign a value, they seem to be the problem.
Cheers
iCON Photography
Old 03-09-2008, 06:52 PM
Ummm... yeah, settings are on a per patch basis, use Copy and Paste.
filosofem
how the heck do I save defaut i/o??? czarthp Pro Tools 9 2 04-13-2011 09:53 AM
Otpimizing Xpand for EWI 4000s midi controller msgood Virtual Instruments 3 02-09-2010 05:12 PM
Xpand! controller (this might be a really stupid question) Michael P. Virtual Instruments 5 03-28-2008 10:50 AM
Making Midi Assignments stick in Xpand JohnnyG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-05-2006 05:15 PM
midi controller assignments... why is this not simple? pleasedonthitme MIDI 0 04-29-2003 11:04 PM
