Old 03-21-2022, 09:31 PM
cristtiah cristtiah is offline
Default Avid Omni and Cranborne ADAT and 4 analog IN/OUT
Hi can the Avid Omni connect to a Cranborne ADAT for 8 channels of IN/OUT and still use the 4 analog input and outputs?
Old 03-21-2022, 11:15 PM
nst7 nst7 is offline
Default Re: Avid Omni and Cranborne ADAT and 4 analog IN/OUT
The Omni only does 8 channels total, so you could do 4 adat and 4 analog, or 8 adat.
Old 03-22-2022, 05:05 AM
epm epm is offline
You're hard limited to 8 outputs with the omni, but you can bring up any number of inputs in the hardware mixer and route them directly to the monitor path and/or cue output, even if they aren't defined as inputs in your pro tools i/o setup.
I use this to monitor my system audio via spdif, and various adat inputs when I just want to listen to them but not necessarily record. The only (slightly) annoying part is that the hardware mixer setup / controls are in pro tools and not in a separate hardware setup application.
-Evan
Omni to C24 Analog 7-8 KGraham045 ICON & C|24 0 08-23-2016 07:14 PM
Avid Omni as a standalone "analog to adat" converter. Is it possible? Kokos Pro Tools HDX & HD Native Systems (Win) 5 03-14-2016 07:31 AM
+4 dBu or -10 dBv analog in Omni chrisdee Pro Tools HDX & HD Native Systems (Win) 2 10-07-2012 04:15 PM
Are Omni Analog ins calibrate-able? Picture Start Pro Tools TDM Systems (Mac) 7 10-07-2011 08:07 AM
01V 18bit analog omni outputs? east3rdst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-07-2001 08:26 PM
