Old 10-26-2022, 06:48 PM
Brandonx1 Brandonx1 is offline
Default Opening a session created in 2022.10 in 12.7.1
I am going to run into a situation where I will need to move a mix from my studio to another studio that runs 2022.10. I like to use the new ARA Melodyne to fix dialog edits. Does anyone know of a good way to move to a version of pro tools without Melodyne? I would like to avoid freezing tracks but would be open to just committing the ARA audio. Can you do that in 2022 10?
Thanks for the help.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 10-26-2022, 07:48 PM
its2loud its2loud is offline
Default Re: Opening a session created in 2022.10 in 12.7.1
Yes. Commit your audio. Remove Melodyne from the track and you’re good to go.
Old 10-26-2022, 08:33 PM
I'm going onuse it via ara tho. Normally I make a selection, right click>Melodyne> edit. How do you remove that? I don't normally select Melodyne from the ea track based menu.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 10-26-2022, 08:43 PM
It shows up under the track name where you usually enable elastic audio. But as long as you render the audio, you’ll be ok. Removing it is an extra precaution.
Old 10-27-2022, 05:04 PM
Ok I see now. No matter what way you enable Melodyne, it will show up in the EA menu enabled! Thanks!
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 10-27-2022, 10:13 PM
Correct. And it stays enabled even if you render the audio on a particular clip on that track.
HTML code is On
Problem Opening Session created on PT HD 8 sheckybass Windows 3 06-04-2012 12:21 PM
opening midi session created in 7.3 in 8.0 guitardom MIDI 6 07-02-2011 10:03 AM
Opening session created on PC with my MAC? Faulty Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-17-2007 10:41 PM
Opening a session created on another system Joel Newport Pro Tools TDM Systems (Mac) 5 07-14-2005 09:15 AM
Opening a session created on a mac Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-31-2004 05:52 PM
