Old 12-19-2014, 04:34 PM
armytanker armytanker is offline
Default Playback Quality/Horrible
Hey all,
I'm running PT 10.3 using OS 10.7.5 with a digirack 003+ and when I play sessions in PT, sounds fine....now when i bounce to disk with these settings;
MP3, Interleaved 16bit, 44.1, tweak head(slowest), convert during bounce.
When I play it back on my phone or iTunes...I get really bad clicks and all kinds of horrible stuff. My band mates on their devices hear it. It's like during bounce, something is happening to the quality. Now these are just guitar riffs that I recorded, so they are not full sessions.
Any ideas on fix?
Thanks!
2006 MacPro "Quad Core" Intel Xeon processors, 2.66GHz, 6X Superdrive, 7Gb, OS X 10.7.5, Digirack 003+, PT10.3.8
Old 12-19-2014, 04:54 PM
Craig F Craig F is offline
Default Re: Playback Quality/Horrible
convert after
bounce as wav
convert to mp3 on import to iTunes if you need it
Thank you,
Craig
Old 12-19-2014, 04:57 PM
mesaone mesaone is offline
Have you double-checked your bounce source, to make sure you're bouncing what you intend to?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 12-19-2014, 05:59 PM
Originally Posted by Craig F View Post
convert after
bounce as wav
I did and a couple issues with that is that the volume comes out way low...I have to max a lot of the settings in PT to bring it up and you what happens with that? lol More cracks clips and other nonsense. And I need my band mates to listen to it in mp3 format....and it doesn't email in wav...atleast it won't with aol.
Bounce source is ANalog1-2(Stereo)-> Analog 1-2...looks like the right source to me.
Old 12-19-2014, 06:13 PM
Something else I noticed at the beginning of the track there's no audio because I haven't played, the moment I start playing is when it starts to to cracks, almost like a really bad click track....like a bad skip on a CD....does that help? lol
Old 12-20-2014, 08:02 AM
berre berre is offline
hey guys !
i'm new here ... and I registered up because i've got just the same problem since yesterday and was looking for a solution.
been working and mixing since a week or 2 on live recordings of my band, never had any problem when i was bouncing mixes to WAV and MP3, all sounded great !
yesterday did some last tweaking, bounced it with the same bit depth and sample rate as earlier, but now there's a annoying crack in the playback ....
what the hell happened ?
please advice
grtz,
Berre
Old 12-22-2014, 07:15 PM
So I still haven't managed to find what the problem is with the ticking sounds of the mp3 and wav files that i bounced down to. Anyone have any other suggestions?
Old 12-23-2014, 02:26 AM
real time or non-real time bounce? I'm thinking a PI might not like FRT
Thank you,
Craig
Old 12-23-2014, 03:17 AM
YYR123's Avatar
YYR123 YYR123 is offline
convert after
bounce as wav
Yes yes yes. Also on
Setup
Playback engine
Deselect ignore errors during playback
Daniel
Old 12-23-2014, 03:20 AM
YYR123's Avatar
Also need to check specs on computer. If a hard drive is under spec could cause issue
If your only recording to 1 drive (no secondary drive) will cause issue
Drivers updated? Why aren't you running at least 10.3.7?
Daniel
Horrible Distortion on Playback javaman717 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-23-2009 03:50 AM
Recording quality suddenly horrible? PT8 - files in here. masta1 Pro Tools M-Powered (Win) 7 04-03-2009 10:11 AM
Mixdown quality is horrible Mad Genius Audio Pro Tools M-Powered (Win) 10 06-29-2006 06:58 AM
Quicktime playback quality Jerome Cuendet Post - Surround - Video 9 03-18-2006 05:30 PM
Horrible, Horrible, Skreeching Noise On Drum Track in Sampletank William.E.Lemuel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-09-2002 06:54 AM
