Record problem, signal stuck at -8db!
Ok, I already have used this protools on my computer for like 1 year, then all of a sudden I got this problem, for no reason, I was ready to record a track, then I was positioning my microphone, and then when I pressed record the signal stuck at like -8db, I hear no sound, but its there, frozen at -8db, I can't record, and if I do so, all I get is a 'stucked -8db wave with no sound', I already tried to: reset pc, re-install protools, unplug and then plug again my m-audio, all those basic stuff.
Re: Record problem, signal stuck at -8db!
Are you still having this problem? I see you posted this last month. What type of recording hardware are you using? I'm assuming your using an M-Audio product. And also, what are your recording and playback settings? What is the buffer settings? Is your sound card set to the same sample rate/bit depth as PT?
keep getting stuck on record pause | CD551 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-10-2009 07:59 AM |
Track Level Stuck, no signal? | gabjaz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-07-2008 01:11 AM |
MIDI Record Stuck On | CharlieX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-06-2007 12:48 PM |
Stuck in Pause - Can't play or record | davegilliss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-15-2005 10:02 AM |
Record button is stuck | bubblebeat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-05-2003 05:21 AM |
